Mk2 Golf 1989 Cl
162 replies to this topic
#61 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 13 May 2018 - 03:49 PM
Managed to prep for some more epoxy primer today, scuffed, hand sanded bare steel then panel wiped about 20 times.
Pictures.
#62 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 May 2018 - 07:56 PM
It's looking really good!
Almost like a new shell.
Are you going back to Silver?
#63 cookie4343
cookie4343
  • 2,257 posts
Posted 13 May 2018 - 08:01 PM
Cheers Ben.  Trying to find a nice blue that's not to in your face bright. I have Ral 5012 but not convinced and I also need to find some space somewhere to spray it.
Edited by cookie4343, 13 May 2018 - 08:01 PM.
#64 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 13 May 2018 - 11:10 PM
Helios blue is nice, not sure if its what you're going for though. Epic work!
#65 Baldspeed Racing
Baldspeed Racing
  • 1,189 posts
Posted 14 May 2018 - 06:42 AM
Always one mate, ignore and if you are working on it in social hours you will be fine. Unless you're not covered to work in the garage area if council owned if you know what I mean
I'm a private tenant not council, i get on and talk to most my Neighbours. I'm a reasonable person but would appreciate someone to come directly to me so we could come to a agreement. I'm not going to stop, It's not going to be forever and as far as i'm concerned everyone's entitled to a hobby.
Thanks for taking your time to read and comment.
No worries at all, its good to see the progress on the shell to be fair, I need to get under my Mk3 as some point as I think the sills needs a bit of tlc
#66 cookie4343
cookie4343
  • 2,257 posts
Posted 14 May 2018 - 06:51 AM
The problem with vw's is the spray sealer they use at the factory, don't get me wrong it's good stuff but cracks, goes hard then lets water in.
Appreciate the encouragement from you all.
#67 cookie4343
cookie4343
  • 2,257 posts
Posted 16 May 2018 - 12:20 PM
New jacking point stumps arrived yesterday, so thought id get them fitted today.
New stumps drilled for plug welds.
Weld primer applied.
Drivers side welded and cleaned up.
Passenger side welded and cleaned up.
Forced a load of epoxy primer in each side with spray gun and brush, looks messy but will clean it up after It's dry.
Drivers side.
Passenger side.
#68 cookie4343
cookie4343
  • 2,257 posts
Posted 19 May 2018 - 06:06 PM
Did a bit more today mainly seam sealing and some more primer.
First I spot blasted around the floor blanks and masked them for some primer.
Floor blanks blasted ready for primer.
Floor blanks primed and refitted and seam sealed.
Underside floor seam sealing.
Spot blasted some rust.
Epoxy primer.
#69 cookie4343
cookie4343
  • 2,257 posts
Posted 26 May 2018 - 05:48 PM
Removed headliner last week. Removed sound proofing and glue residue from inside roof skin which left me with some rusty spots.
I spent a few hours today spot blasting and sanding ready for some paint for protection before more soundproofing.
Applied some epoxy primer.
Then applied raptor straight after wet on wet thinned for gravity fed gun.
Hopefully that has protected the inner roof skin for a few more years. I will more than likely stick some spray wax in the cavities before re fitting the headliner.
#70 cookie4343
cookie4343
  • 2,257 posts
Posted 28 May 2018 - 05:34 PM
Few more hours managed today.
Fitted some new sound proofing to inner roof skin, I've used a lot as the roof skin was pretty flimsy and tinny before.
Did a load more seam sealing.
#71 cookie4343
cookie4343
  • 2,257 posts
Posted 01 June 2018 - 03:41 PM
Accidentally did this, wife's not happy.
#72 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 June 2018 - 05:56 PM
Brave man
#73 cookie4343
cookie4343
  • 2,257 posts
Posted 01 June 2018 - 06:13 PM
Brave man
Practice run, no messing about full floors no patches. Ill stick up a project log when it arrives.
#74 cookie4343
cookie4343
  • 2,257 posts
Posted 02 June 2018 - 06:15 PM
Tested some paint today.
#75 james962
james962
  • 2,677 posts
Posted 02 June 2018 - 07:07 PM
Hi Steven, hope you and the family all are well, long time no see. The work you are going on the Golf is looking great; I'm looking forward to seeing this progress  =]  I like the colour, what colour code did you go for in the end?
