Mk2 Golf 1989 Cl
162 replies to this topic
#31 cookie4343
cookie4343
    **Caution: Do Not Feed Alcohol**
  • 2,257 posts
  • Local Club: CV1 Mini's
Posted 15 April 2018 - 05:41 PM
Today i finished getting the tunnel to bare metal ready for epoxy primer.
Sandblasted jacking point stump area, it will need a patch as blasting has created some pinholes.
Epoxy primed the drivers main floor and tunnel.
This week im going to try get the new battery tray welded. My shoulders and arms hurt abit right now.
#32 cookie4343
cookie4343
  • 2,257 posts
Posted 16 April 2018 - 12:53 PM
Battery tray welded in, just need to finish a small repair at back of tray and grind the lot down.
Penetration on Inner wing.
Plug welds along chassis rail.
Ground these down and finished, sandblaster will sort the rest.
#33 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 16 April 2018 - 12:59 PM
Looking good, used to have a mk2 myself have to find some photos of it, are you going to keep the engine stock?
#34 cookie4343
cookie4343
  • 2,257 posts
Posted 16 April 2018 - 01:26 PM
Yes engine will stay standard apart from the Webber carb and maybe a gti cam. Thanks for reading.
#35 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 16 April 2018 - 01:35 PM
Ah awesome will be a lot of fun then, I may have a GTI cam for the 8v at home if you want one, I swapped mine with the 2.0 16v from the mk3 GTI was plenty of fun
#36 cookie4343
cookie4343
  • 2,257 posts
Posted 16 April 2018 - 02:01 PM
Thanks for the offer, If you find it let me no and depending on cost I could be interested. Im just trying to build a reliable engine really, 16v vr6 etc never really bothered me. Looking at just replacing seals etc on current engine and giving it a tart up and hope all internals have some life left in them.
#37 Baldspeed Racing
Baldspeed Racing
  • 1,189 posts
Posted 17 April 2018 - 06:45 AM
Coming along well fair play
#38 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 17 April 2018 - 01:15 PM
Same colour interior as ours,and some hard work going on that sealer is a pig,I just removed 2”past effected area to make sure all rust removed the factory sealer is brilliant it only fails if cracked
#39 cookie4343
cookie4343
  • 2,257 posts
Posted 17 April 2018 - 05:02 PM
Thanks mate.
#40 cookie4343
cookie4343
  • 2,257 posts
Posted 17 April 2018 - 05:08 PM
I wasn't going to bother removing the sealer but i mainly did it for piece of mind, Vw did a good job to be fair it's not done bad for 29 years old.The interior has now gone except the carpet. Not sure if ive going to do the underneath in body colour or just black.
Thanks for commenting.
#41 cookie4343
cookie4343
  • 2,257 posts
Posted 18 April 2018 - 12:32 PM
Done a few hours this morning, got the battery tray finished.
Plug welds all grind'ed down.
Chassis rail close panel cut out ready for repair.
I had a piece of old chassis that came with the car so cut out what I needed. No welding pics as I just got on with It.
I will more than likely give it a light skim of filler to finish.
Edited by cookie4343, 18 April 2018 - 12:36 PM.
#42 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 18 April 2018 - 09:30 PM
Looking great! Love a MK2, nearly finished my MK2 VR6 project. Owned it 4 years this year.
What epoxy primer are you using?
#43 cookie4343
cookie4343
  • 2,257 posts
Posted 19 April 2018 - 06:56 AM
Hi im using spectral under 385  I find it pretty good. Ive only just started using epoxy so dont have a lot of experience, I used to use etch but had a few problems with it.
#44 Boycie
Boycie
  • 1,978 posts
Posted 19 April 2018 - 07:25 AM
You're doing a fantastic job there, keep it up! Looks like a very good 'shell too.
#45 cookie4343
cookie4343
  • 2,257 posts
Posted 21 April 2018 - 06:36 PM
Today's job, Sandblasted passenger side front engine bay.
Epoxy primed
Edited by cookie4343, 21 April 2018 - 06:40 PM.
