Mk1 1961 Rebuild Project,not For The Faint Hearted
Posted 18 February 2018 - 01:01 AM
So to the details, he's a 1961 Mk1 with a 998 heart which needs some nurturing, this sits on top of a bog standard gearbox with remote gearstick. The gearbox will be having major surgery, complete strip and rebuild using close ratio straight cut gears, 1:1 straight cut drop gears, cross pin diff and central oil pick up.
His floor is gone beyond repair so will be replaced with a complete new floor, which will mean that the rear sub frame will be able to be reattached to the car as at present it's sitting on the floor about 10 feet away.
I'll endeavour to get some photos of this handsome boy up tomorrow. Looking forward to catching up with some old mates over the next few months as the project goes forward.
Andy
Posted 18 February 2018 - 08:48 PM
Apologise for the large amount of photo's but I seem to remember from before that everyone likes photo's
Andy
Edited by Mini Basher, 18 February 2018 - 09:28 PM.
Posted 19 February 2018 - 06:45 AM
This looks like an ace project! Looking forward to seeing this one come together.
Posted 19 February 2018 - 08:01 AM
Thanks minimissions, I don't know which is the worst his one or the one I did before, but I do like a challenge and I was starting to get a bit bored.
Posted 19 February 2018 - 08:10 AM
Posted 19 February 2018 - 12:40 PM
haha its all good fun, I am sure you will get this one done to.
Posted 20 February 2018 - 12:51 AM
Been and done a bit on the mini tonight. When I took out the rear screen there was some rot to the right hand bottom corner of the window opening and also to the rear parcel shelf on the same side.
So I cut out the rot then started fabricating some new metalwork and welding it in and grinding it down
Then I repaired the rear shelf
Still need to fettle the welds a bit, but pretty happy with a couple of hours work.
Edited by Mini Basher, 20 February 2018 - 10:02 PM.
Posted 20 February 2018 - 10:37 PM
Back in the workshop tonight for another couple of hours, I've removed the radiator and hoses ready for the removal of the engine at the weekend. I've removed the passenger door and welded braces in place across both drivers and passenger doors, I've also welded some diagonal bracing through the interior to help stiffen the bodywork as there is a lot of rot in the floor and the front panels
Also i've removed both of the front wings to see what nasties are lurking in the dark
and now for the passenger side
I think I need to order some panels and a big bottle of gas for the welder, good thing I enjoy the welding part of things
Posted 21 February 2018 - 06:43 AM
Nice progress so far, I have defo seen worse mk1 minis
Posted 21 February 2018 - 10:09 AM
is it finished yet! Fair play shes going to need some work but well done on saving her
Posted 21 February 2018 - 01:23 PM
Im aiming to do a few hours each evening and as much time as possible at weekends so we'll see how it progresses. Ordered my steel this morning to make a carosel, did this last time and it made everything so much easier, just wish I hadn't scrapped the old one about 18 months ago. Hopefully get some pictures up later.
Posted 21 February 2018 - 03:59 PM
Looking forward to this.Your a fast worker!
Posted 21 February 2018 - 04:34 PM
Taking it apart is the easy bit, its putting it all back together so that everything still fits that takes the time.
Posted 21 February 2018 - 05:19 PM
Posted 21 February 2018 - 05:37 PM
You don't seem as though you're short of motivation but I like to totally re-furbish something smallish like a rocker cover then leave it where you can see it to encourage the rest of it!
Projects โ
Mini Saloons โ
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 ![]() |
Projects โ
Mini Saloons โ
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 ![]() |
Projects โ
Mini Saloons โ
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 ![]() |
Projects โ
Mini Saloons โ
Mpi Dashboad ProblemStarted by mikeprez , 22 Dec 2021 ![]() |
Projects โ
Mini Saloons โ
1978 Oew - Willy The MiniStarted by smalltreegrower , 11 Nov 2021 ![]() |
