1293 Turbo Engine
97 replies to this topic
#31 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 12 March 2018 - 09:46 PM
You'll find it hard to stick with low boost! It's addictive
The reason I want to make the bottom end strong/reliable. I will take it easy at first, because It's a new engine, then pile on the boost over time. And a dump valve, because it has to be done, even if it's classed as 'chavy'.
#32 jt19
jt19
  • 745 posts
Posted 12 March 2018 - 10:15 PM
Dump valves are important to save the turbo from stalling. Which can supposedly break the turbines.
#33 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 18 March 2018 - 08:08 AM
Playmini 2 inch. :D
29244163_891199191061541_335729012915448
#34 Steve220
Steve220
  • 5,026 posts
  • Local Club: BMC
Posted 18 March 2018 - 09:15 AM
Playmini 2 inch. :D
Out of curiosity, is it 2 internal diameter piping or just the tailpipe and is it stainless?
#35 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 18 March 2018 - 03:47 PM
Playmini 2 inch. :D
I assume It's ID. It's 2'' all the way to the backbox, and the tail pipe is 2.5''. The downpipe is 3'' at the elbow, then 2'', I believe. It's made to fit a 2'' exhaust.
#36 Steve220
Steve220
  • 5,026 posts
  • Local Club: BMC
Posted 18 March 2018 - 04:53 PM
Im worried itll be too restrictive for the power Im after.
#37 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 18 March 2018 - 07:06 PM
What spec/power you after? I'm told it's the exhaust to go for, and will have no restriction. The main point is you can't get much bigger on the downpipe. 3 inch would probably not fit between the tunnel and the gear linkage anyhoo, even if you could somehow fit a 3 inch downpipe. I'm planning on fitting a Fusion Fabs manifold kit.
#38 Steve220
Steve220
  • 5,026 posts
  • Local Club: BMC
Posted 18 March 2018 - 07:13 PM
From the calcs, 2" (1.75" ID) will be restrictive for the flow at 12psi (150bhp). I'm after a 2.25" OD mandrel bent system.
#39 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 18 March 2018 - 07:38 PM
Give it a go and see what happens. :highfive:  Just make sure the downpipe will fit. :shy:
#40 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 18 March 2018 - 08:03 PM
Plenty of folk make decent power on a 2" downpipe, but if you can fit bigger in go for it. You want the least possible restriction after the turbine & unlike a NA engine you can't really go to big on a turbo motor.
Phil.
#41 mini13
mini13
  • 3,810 posts
Posted 18 March 2018 - 11:08 PM
Ive just done myself a 2.25" bore mandrel system, I was considering doing another to sell, I could look at doing one for you if you want, I have Tig stuff for stainless, and can stretch pipes to do slip joints.I did make the backbox for mine with a carbon can, but it was a PITA, next time I would just get a stainless box off the shelf, then its just a matter of geting a couple of 30 deg bends and sone cutting welding etc,
i dont have any good pics of mine, but managed to find these, it was extra tight being a remote box, rod change would be easier.Attached File  DSC_1511JPG.jpg   40.18K   5 downloadsAttached File  DSC_1513JPG.jpg   46.75K   4 downloadsAttached File  DSC_1512JPG.jpg   35.49K   2 downloads
#42 Steve220
Steve220
  • 5,026 posts
  • Local Club: BMC
Posted 19 March 2018 - 08:31 AM
i dont have any good pics of mine, but managed to find these, it was extra tight being a remote box, rod change would be easier.attachicon.gifDSC_1511JPG.jpgattachicon.gifDSC_1513JPG.jpgattachicon.gifDSC_1512JPG.jpg
Wow! That's an awesome offer, Joe!
Edited by Steve220, 19 March 2018 - 08:36 AM.
#43 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 19 March 2018 - 01:10 PM
What do you use to stretch the pipes for slip joints Joe ?
Phil.
#44 mini13
mini13
  • 3,810 posts
Posted 19 March 2018 - 01:43 PM
essentially this setup,
https://www.ebay.co....4UAAOSwKXdabVuh
#45 miniallsort
miniallsort
  • 4,723 posts
Posted 26 March 2018 - 09:55 PM
interesting read following the progress
