Mini Sprite 1275 Vs Mini Cooper 1275
Best Answer FlyingScot , 02 February 2018 - 05:06 PM
If your talking fuel injection Cooper has a higher output engine courtesy of a higher compression ratio (different pistons) and a different ECU (different fuelling curves) from memory 50 Bhp versus 63
FS Go to the full post
19 replies to this topic
#16 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 03 February 2018 - 03:13 AM
Have a look through the brochures here: http://www.minipassi...s/brochures.htm
Eg. 1994 http://www.minipassi... range 1994.pdf
Sprite = 53hp
Cooper = 63hp
#17 Arthy
Arthy
  • 112 posts
Posted 03 February 2018 - 02:03 PM
I remember reading somewhere that adding a good head, 1.5 rockers, HIF44 and a recurved dizzy to a stock sprite engine & cam, it's possible to get 80+ BHP. Very drivable too from what I remember reading.
For a start, the obvious is a stage 1 kit. It made a hell of a difference to mine!
Does adding that kit affect insurance dramatically?
I never did tell them........ Your choice, but I presume it would increase depending on your age and so on!
#18 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 03 February 2018 - 06:58 PM
1992 coopers are injection
#19 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 03 February 2018 - 08:48 PM
Thats a bit random
#20 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 03 February 2018 - 09:00 PM
Thats a bit random
What I meant was 1992 onwards coopers are injection, all other models(Inc LEs upto October 1994) are carb. I say this because we have an Italian Job LE and a sprite which are both L reg cars, both are fitted with identical spec(needle and spring/jet) HIF 38 carbs
