What Light Weight Battery Do You Use?
Posted 23 January 2018 - 09:27 PM
Posted 23 January 2018 - 09:48 PM
hi racer pete
the lithium motorcycle batteries are an excellent choice.
here is a link to the ones i know of , but i am in ozzztralia, so do your own research.
http://www.ssbpowers...32/default.aspx
the one i use has about 450 CCA and has kicked over my mini at minus 6 degrees(celsius) using 25 / 50 weight oil,,,, it fits under my passenger seat and weighs about 1 kg. ( the odyssey before that was 7kg in the rear.. so i installed it to ensure i didn't need to go on a diet myself..you never ever ever blame the driver for poor driving or being too heavy if you can spend money on some go fast parts!!!! joking of cause but often true))( Good job on your car weight loss by the way)
there are better and slightly smaller battery versions out now, they are rated for about 2000 cycles and i have been impressed with their holding state ( keeping charge for 3 months whilst idle.) ( however they do need a lithium type charger eg ctek and i would recommend trickle charge in between outings anyway) mine has done duty for 3 seasons of racing so far and is still in tip top shape BUT i dont use it as a daily. I also recommend wiring it up to an anderson plug and then you can use a jump starter pack to assist where and if necessary ( eg bringing up oil pressure before first start)
They do not like shorting out even for an instant.....i killed one when connecting to my kill switch ( ironic huh)
To be honest , unless only a racer i would stick with an odyssey... tried and true and a good all rounder
Posted 25 January 2018 - 10:57 AM
I have my Odyssey pc680 3 years now. and i had never problems with this battery. i would not change this reliability with another battery.
Posted 25 January 2018 - 01:43 PM
Posted 27 January 2018 - 08:11 PM
Posted 30 January 2018 - 11:47 PM
Would recommend it.
Just bought the cheapest YTX-14 off eBay I could find. Only 900g :).
Posted 31 January 2018 - 07:28 PM
Another vote for Odyssey batteries.
