Gearbox Locking
Best Answer johnR , 23 January 2018 - 03:32 PM
Thanks all: you're quite right mini13 - once the pinion was on and nut was tightened up even a little it all freed up. whew! Go to the full post
5 replies to this topic
#1 johnR
johnR
  • 2,302 posts
Posted 23 January 2018 - 11:29 AM
I've re-built my gearbox with new baulk rings and bearings. When I bolted on the main double roller bearing locking casting it went tight to the casing but the gears would only move about half an inch each way before seeming to come against an obstruction. Loosening the casting off allows the shaft to turn. I've tried the original thin shim with no improvement - is it ok to pack this out further and to what thickness? Also when reverse is selected neither shaft will move - does it look as though I've made a mistake?
#2 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 23 January 2018 - 12:25 PM
It does sound like the bearing needs more shims, have a search on here there will be thread that covers exactly how to do it correctly...or the workshop manual.
All looks ok on the photos
Reverse wise it needs checking that its moving properly and that the gear is the right way round. You might also find new baulk rings can stick to the cones a bit.
#3 Ethel
  • 26,061 posts
Posted 23 January 2018 - 12:32 PM
Try it without the layshaft, you may discover it's sticky baulk rings.
#4 mini13
mini13
  • 3,811 posts
Posted 23 January 2018 - 02:04 PM
Put the pinion and nut on,
#5 johnR
johnR
  • 2,302 posts
Posted 23 January 2018 - 03:32 PM   Best Answer
#6 mini13
mini13
  • 3,811 posts
Posted 23 January 2018 - 05:42 PM
Excellent,
Often the 1st gear synchro binds, and needs pulling away by torturing the bearing
