Spi Head Vs Mg Metro?
20 replies to this topic
#16 Shooter63
Shooter63
  • 967 posts
Posted 13 November 2024 - 10:27 PM
I wouldn't worry about fitting inserts with the 35.6mm inlet. You'll find every single aftermarket supplier sells heads with a 36-29 valve combination and inserts, it's very rarely a problem. From the flowbench work I've done the big valve head doesn't flow a huge amount more than its smaller valved counterpart, but with a few very simple mods, and without even touching the ports, some impressive gains can be seen.
Phil.
Sorry to revive an old thread but did this get written up re the β€˜simple mods β€˜ ?
Simple mods tend to be 3 angle valve seats, back cut valves where you cut a 30 degree cut on the back of the valve which also reduces the valve seat to a minimum of 60 thou or 1.5mm in new money, also remove the raised edge around the valve seat.
Shooter
#17 Davetom
Davetom
  • 21 posts
Posted 13 November 2024 - 11:28 PM
Thanks πŸ‘
#18 Turbo Phil
Turbo Phil
  • 2,423 posts
Posted 21 November 2024 - 07:51 PM
I covered all these mods in some videos on my YouTube channel.
Phil.
#19 cooperd70
cooperd70
  • 698 posts
Posted 22 November 2024 - 10:51 AM
Phil. Will I find you easily on YT just by searching for 'Turbo Phil'? Cheers πŸ™‚
Phil.
#20 Turbo Phil
Turbo Phil
  • 2,423 posts
Posted 22 November 2024 - 02:07 PM
Phil.
https://youtube.com/...NuDTnDGCa4RxOc1
Phil.
#21 cooperd70
cooperd70
  • 698 posts
Posted 22 November 2024 - 04:20 PM
Cheers Phil πŸ‘
Phil.
Phil.
