Classic Mini Diy - How To Install Clutch Master Cylinder
6 replies to this topic
#1 xydte
xydte
  • 141 posts
Posted 20 January 2018 - 08:03 PM
On this video i made a tutorial on how to replace the Clutch Master cylinder. I searched youtube and i saw that no one had upload this so here you go. It's a very easy job. 80% easier than the time that i replaced the brake master cylinder.
#2 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
  • Local Club: Birmingham Mini Owners
Posted 07 January 2021 - 09:44 PM
Another way to do this is to put something heavy on the pedal, fit the clevis pin and split pin via the engine bay with long-nose pliers and THEN place the master cylinder and nut up. Saves all the pain and gymnastics involved in doing it in the car.
#3 leyland73
leyland73
  • 158 posts
Posted 08 January 2021 - 06:58 AM
Must have been done this way on the assembly line, couldn’t see the antics I’ve got up to in trying to replace clevis pin inside the crossmember occurring on a moving production line!
#4 Chris1275gt
Chris1275gt
  • 938 posts
Posted 08 January 2021 - 04:52 PM
Now that's a good idea you want to be careful your foot doesn't fall off!
#5 xydte
xydte
  • 141 posts
Posted 15 January 2021 - 11:17 PM
how didnt think of that before. should be way easier
#6 nicklouse
  • 18,574 posts
Posted 15 January 2021 - 11:44 PM
My only comments are it ain’t 13mm. And you did not show how you got the clevis pin in.  A Fork makes it easy.
#7 Mini-Hazel-Nut
Mini-Hazel-Nut
  • 607 posts
Posted 18 January 2021 - 10:59 PM
When I put mine in via the engine bay the only problem I had was I kept dropping the clevis pin right at the critical moment. I solved that by securing the pliers handles with a cable tie, went straight in then. So much easier than breaking your back and going cross-eyed on the floor.
