Drum Brake With Spacers
3 replies to this topic
#1 ings
ings
  • 201 posts
Posted 05 January 2018 - 12:57 PM
I have decided to swap my standart drums to the spacered versions. Most people hate spacers but the integratet spacers are standart in some S modells or later models, so it should be not that bad.
It is a litte bit a experiment, because i never saw a mini running the wide drums in front, most people switch directly to the discbrakes. the price of 12£ for a drum is unbeatable.
My mini had these all around...
Now i have installed the 1" wider Brakes on the rear and the front. And yes you need new longer studs.
Here a side with no spacers
And here with spacers
The rear is an easy job and takes max 2 hours. The front is much more work because it is not so easy to change the studs. i also took the chance to switch from the old ball-bearings to tappered Roller bearing.
Next thing is to adjust the suspension and costumize the arches. my plan is to run more camber to get the rubber under the arches.
#2 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 05 January 2018 - 02:05 PM
I'm running spaced drums all round on my 1275 E as well. It was a necessary fitment as the rear tyres were rubbing against the shock dust covers. It is nice that it adds a little poke to how the wheel sits. Have you considered getting discs for the front?
#3 ings
ings
  • 201 posts
Posted 08 January 2018 - 07:43 AM
Nice im not the only one.
converting to discs is not allowed in switzerland. otherwise you need a lot of certificates.
The good thing with drums is they do not cover your wheels in dust, and they are cheap in service.
#4 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 08 January 2018 - 04:44 PM
Ah, that's unfortunate regarding the disc brakes. Still, at least the spaced drums will work well :)
