Is it ok to use 20 wt synthetic oil in my HS4 carb? Thought i was buying just 20 wt until i got home and saw it was synthetic. I have a 1990 998cc Mini. Thanks
Dashpot Oil
Posted 02 January 2018 - 11:40 PM
Posted 03 January 2018 - 12:16 AM
Posted 03 January 2018 - 02:39 AM
Synthetic has the advantage that it is more resistant to temperature induced viscosity changes which is an advantage in the dashpot for more consistent response.
Posted 03 January 2018 - 05:49 AM
I've never used proper SU dash pot oil but I believe it's a very light weight oil, much thinner than engine oil.
Posted 03 January 2018 - 09:03 AM
Not really true. Its still rated eg 20w50 and Will behave like a 20 when cold and like a 50 when hot. Thats why they give it those numbers in the first place.Synthetic has the advantage that it is more resistant to temperature induced viscosity changes which is an advantage in the dashpot for more consistent response.
The OP's oil Will Just behave like a 20 when hot and cold.
Edited by Dusky, 03 January 2018 - 09:11 AM.
Posted 03 January 2018 - 09:12 AM
Posted 03 January 2018 - 10:17 AM
Posted 03 January 2018 - 11:38 AM
A function of the oil is to provide acceleration enrichment by slowing the piston lift - thicker oil = slower piston rise= more enrichment. If you've changed nothing else, when you put your foot down is when you'd know you've got it wrong. You could also see slightly richer running if you slightly increase the throttle opening, but not enough to generate sufficient pressure differential across the piston to overcome the stiction, increased by thicker oil.
BL/Rover did specify engine oil and they set up the carb to match the engine, I'd take their spec as your starting point.
While it's true, synthetic or mineral, your oil will have to have met grade stated; synthetics are likely to offer a straighter temperature/viscosity gradient that tails off less outside the grades. If it's a single grade engine oil the viscosity will be @ 100oC as an approximation of running temperature, your carb dashpot won't get that hot.
Posted 03 January 2018 - 01:42 PM
But 20 synthetic behaves more linearly with temperature than 20 conventional which is why it is preferred. It's in "the Bible".
Posted 03 January 2018 - 05:54 PM
The SAE20 oil as recommended by SU is a lot less viscous than 20W50 engine oil at the temperatures you're likely to get in a SU dashpot.
So using the SU recommended oil your carb piston will open quicker than using 20W50.
Which may or may not be a good thing depending on the needle profile, how the carb is set up, and what driving characteristics you are hoping to achieve.
Posted 04 January 2018 - 12:37 AM
Thank you all very much. . i see there is a bit of disagreement about the oil type. I will start with 20wt/50wt and then try my 20wt. Thank you all for your input. Wish i was in the UK
Posted 04 January 2018 - 02:19 AM
I would tend to go the other way, start with the the thinnest which would be ATF, approximately 8 wt. and do a few throttle punches at various RPM to see if there's any significant hesitation. If there is, go up in viscosity until the transition is smooth. Going higher in viscosity than necessary to give smooth transition will just slow throttle response with no benefit otherwise.
Edited by hhhh, 04 January 2018 - 02:20 AM.
Posted 04 January 2018 - 05:52 PM
+1 for above.
As alternative to ATF there is also Castrol 10W motorcycle fork oil, available in Halfords in 500ml bottles for about £10. If you need to increase viscosity just blend in some 20W50 engine oil until you get the desired response.
Posted 04 January 2018 - 06:05 PM
Ac
