Moss Aluminium 7 Port Head
13 replies to this topic
#1 AndrewK
AndrewK
    Just On Tickover
  • 7 posts
Posted 30 December 2017 - 02:43 PM
Hi,
I'm about to start building an engine my car. I have been looking around for some cylinder heads, and have found that Moss make an aluminium 7 port head.
I know to avoid the Minisport heads, but has anyone got any experience with these Moss heads? I can't see anyone mentioning these before, are they new???
https://www.moss-eur...inder-head.html
Thanks in advance.
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 30 December 2017 - 03:17 PM
Just had a look and the one thing that strikes me is the size of the valves. The SC 7 Port head valves are much larger and would help to flow much better.
I will be building one of these in the new year (once the bank balance has improved) going on a 1293 bottom end.
#3 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 30 December 2017 - 05:55 PM
Hi,
Thanks in advance.
Just curious on the reasons for "I know to avoid the Minisport heads".
#4 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 30 December 2017 - 06:31 PM
Hi,
Thanks in advance.
Poor engineering.
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 30 December 2017 - 08:42 PM
It looks like the Pierce castings head. They've been around for a good few years now, there were a few companies selling them at one point, including MED.
MED used to sell theirs as modified versions featuring improved porting and larger valve sizes, though they don't seem to list them on the website any more.
As standard they require some "finishing" and the small inlet may limit power, depending on your application ? What's your engine spec and intended use ?
Phil.
#6 mk1leg
mk1leg
  • 9,343 posts
Posted 30 December 2017 - 08:50 PM
Give Vintage Mini a message on Facebook I bought 1 from them complete with 4 bike carbs not had a problem yet after 2 years now
https://www.facebook...?type=3
https://scontent-lhr...22a&oe=5AFA4FCF
Speak to Dennis
#7 AndrewK
AndrewK
    Just On Tickover
  • 7 posts
Posted 30 December 2017 - 09:40 PM
Phil.
Well, my engine at the moment is a standard metro 1275, but the plan is to bore it to 1310cc, Swiftune SW5 cam, 7 port head (twin Weber 45DCOE), balanced crank, lightened flywheel, straight cut box, LSD and ARP head studs.
I was hoping for around 100hp, but keeping it fairly reliable but still fairly quick. I did notice the smaller valves so if needed I will increase the valve size.
I assume if MED used to sell it, it should pretty good?
#8 AndrewK
AndrewK
    Just On Tickover
  • 7 posts
Posted 30 December 2017 - 09:49 PM
Speak to Dennis
I'll keep it in mind whilst I'm in the build process.
Were you able to fit the bike carbs under the bonnet without cutting it? And was it expensive??
#9 minimans
minimans
  • 411 posts
Posted 30 December 2017 - 09:50 PM
Twin 45's? way too much carb for that Spec unless your going to Rev the nuts off it all day. Go for twin 40's for a road car
#10 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 30 December 2017 - 10:40 PM
By the time you've paid someone to cut the valve seats and alter the porting to suit the larger valve or valves and bought the valves it's not going to be a cheap head. Have you looked at the SC 7port ?
Phil.
#11 Midas Mk1
Midas Mk1
  • 5,774 posts
  • Local Club: S.U.N.M.C
Posted 30 December 2017 - 10:44 PM
Far easier ways to get 100bhp, my daily mini gets 97 atf using a tame as (and surprisingly amazing sw5) and still a 5 porter.
7 porters need to rev, so really it's in the application of use. My other mini is a right cammy screamer, but a right pain when trying to daily..
#12 Spider
  • 14,838 posts
Posted 31 December 2017 - 12:38 AM
There has been a lot of issues with the Pierce Heads over the years and I'm not sure they are on top of it.
If you go ahead with this, I'd suggest looking the head over very thoroughly when you get it out of the box, then having it pressure tested before doing anything with it.
Here's one guys experience, though, in this case, a B Series, but I know of similar issues with those for A Series. Seems mostly related to foundry and metallurgical issues.
http://www.mgexp.com...d.php?1,1135858
#13 mk1leg
mk1leg
  • 9,343 posts
Posted 02 January 2018 - 06:22 PM
Speak to Dennis
had a bespoke bonnet made
new%20bonnet%20fitted%201_zps7ihimxcv.jp
#14 AndrewK
AndrewK
    Just On Tickover
  • 7 posts
Posted 16 January 2018 - 10:18 PM
Thank you for all of your responses, I'll take some more thinking time before I make a decision :D
