2 Ltr 8V Clubman
121 replies to this topic
#46 Rich1
Rich1
  • 119 posts
Posted 12 March 2018 - 06:17 PM
Attached File  IMG_1468.JPG   65.96K   1 downloadsAttached File  IMG_1467.JPG   39.33K   2 downloads
So got subframe back from welders
So allspeed frame can now take normal mini bottom arms and tie bars
Edited by Rich1, 12 March 2018 - 06:20 PM.
#47 Rich1
Rich1
  • 119 posts
Posted 17 March 2018 - 09:07 PM
Attached File  IMG_1471.JPG   38.73K   1 downloads
So it's snowing again in Essex great just what we need again
Edited by Rich1, 17 March 2018 - 09:08 PM.
#48 Rich1
Rich1
  • 119 posts
Posted 19 March 2018 - 07:40 PM
Hi Guys
The engine I am using is a cavalier X20XEV 16v I have no engine loom with it are the vectra and Astra the same
What is the best gearbox to use with this engine I do have 2 F16 gearboxes sitting around
Please help
Richie
#49 Rich1
Rich1
  • 119 posts
Posted 14 April 2018 - 08:56 PM
Attached File  IMG_1493.JPG   48.61K   0 downloads
So mini is coming on slowly at the moment have got rear subframe back on and just got my new rubber donuts in post today
#50 robbob1980
robbob1980
    Starting My Mini Up
  • 4 posts
Posted 20 April 2018 - 08:17 AM
I have an F16CR gearbox in mine with an F18WR 5th gear for cruising which works well. Its been a C20NE then C20XE and I've recently turbo'd it and the gearbox is still holding up ok.
Rob
#51 Rich1
Rich1
  • 119 posts
Posted 22 April 2018 - 06:41 PM
Rob
Going to use a f16 gearbox out of my old calibra 2 ltr 8v which is sitting in garage
#52 Rich1
Rich1
  • 119 posts
Posted 01 July 2018 - 05:29 PM
Attached File  IMG_1532.JPG   61.03K   0 downloads
So not much work on mini at moment as working in garden but I have finish the rear roll cage just got to paint the front now
#53 Rich1
Rich1
  • 119 posts
Posted 22 July 2018 - 07:48 PM
Attached File  IMG_1554.JPG   64.76K   2 downloadsAttached File  IMG_1553.JPG   74.42K   4 downloads
So got some paint in engine bay Friday just a few more coats to go and will be spraying inside of mini as well
Edited by Rich1, 22 July 2018 - 07:49 PM.
#54 Rich1
Rich1
  • 119 posts
Posted 30 July 2018 - 07:09 PM
Attached File  IMG_1563.JPG   54.27K   1 downloadsAttached File  IMG_1560.JPG   67.53K   0 downloadsAttached File  IMG_1557.JPG   75.21K   2 downloadsAttached File  IMG_1559.JPG   56.77K   2 downloads
So been painting the inside of the car last week but to bloody hot ,not as much work on car as I like but that's the way it gose
#55 Rich1
Rich1
  • 119 posts
Posted 30 July 2018 - 07:18 PM
Attached File  IMG_1558.JPG   59.22K   0 downloads
So the fibreglass roof turn up today what is the best way to fit the roof to the car as I have never fitted one was going to put a metal one but had heart atrack of the price
#56 Rich1
Rich1
  • 119 posts
Posted 30 July 2018 - 07:21 PM
Attached File  IMG_1556.JPG   75.82K   3 downloads
So hot tub turn up on Monday was out looking for patio slaps but came home with tub instead ?
#57 Bat
Bat
  • 903 posts
Posted 31 July 2018 - 07:33 AM
Hi,
If you're going to run carbs I wouldn't have thought the vauxhall engine loom would be much use?
What are you doing for sparks?
Cheers  :proud:
#58 Rich1
Rich1
  • 119 posts
Posted 31 July 2018 - 09:08 AM
Hi,
Cheers  :proud:
Not sure was going to put in a 2 ltr 8v engine but got a 2ltr 16v engine instead so was going to use bike carbs but have not a clue about the rest yet
#59 Bat
Bat
  • 903 posts
Posted 31 July 2018 - 09:38 AM
Hi,
Personally I'd always go injection. You can use the throttle bodies with injectors in off a bike. A good stand alone ECU and loom will have you pretty much sorted on the 16v
Don't know what the current ignition system on the 8v is.
I'd recommend VEMS as there's a good on-line community to help you get up and running and no expensive cable and software to talk to the ECU.
Cheers  :proud:
Edited by Bat, 31 July 2018 - 09:38 AM.
#60 Bat
Bat
  • 903 posts
Posted 31 July 2018 - 09:44 AM
Hi,
Failing that you could cut up and weld a plenum on to the Vauxhall manifold and make it even easier?
Cheers  :proud:
