Brake Booster Brackets
11 replies to this topic
#1 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 27 December 2017 - 08:40 AM
Hi everyone,
Does someone have a set of brake booster brackets as shown in the photo that they'd be willing to post to South Africa?
Thanks,
Vinay
#2 mini 4o
mini 4o
  • 318 posts
  • Local Club: corfu mini's
Posted 27 December 2017 - 10:42 AM
similar ...  www.minispares.com/product/Classic/MSSK007.aspx
#3 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 27 December 2017 - 12:54 PM
Yeah, I've seen those. Hoping to find some original ones if possible.
#4 GraemeC
GraemeC
  • 7,438 posts
Posted 27 December 2017 - 09:01 PM
They were only fitted to the early (10" wheel) 1275GT in the UK and are pretty hard to come by.
#5 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 27 December 2017 - 09:21 PM
Yeah, probably why they aren't too common here either. Only the GTs and early GTSs had them fitted. Worth a try I suppose.
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 28 December 2017 - 08:26 AM
presumably the set in the photo arent yours?
You might get lucky on eBay, I got a set in there a few years back
#7 mini 4o
mini 4o
  • 318 posts
Posted 28 December 2017 - 09:11 AM
how about a local metal working shop to make some ?  or even better find a laser cutter.... Put's foolish ideas in peoples heads
#8 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 28 December 2017 - 10:11 AM
Yeah, they belong to a friend. Used them to make some CAD drawings in case I couldn't find an original set. Thanks, I'll check on eBay :)
I checked with a local laser cutting and sheet metal bending company, but the design that I took to them was too complex to bend. So I might need to simplify it.
#9 GraemeC
GraemeC
  • 7,438 posts
Posted 28 December 2017 - 10:54 AM
The rear bracket would be simple in a laser cutter and then bend carefully in a vice.
The front bracket I think could be made from a length of box section, especially if you werent looking for it to be 100% the correct dims. To be honest that one looks too bent at the end - I dont think they should turn up quite so much, almost straight with loop underneath
Edited by GraemeC, 28 December 2017 - 10:54 AM.
#10 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 28 December 2017 - 12:17 PM
The hardest bend for them to make I think would be the rounded end. I'll check with the companies in the new year once they re-open.
#11 GraemeC
GraemeC
  • 7,438 posts
Posted 28 December 2017 - 06:27 PM
I don't think that would be too bad - heat the metal up to cherry red and wrap it round some bar.
#12 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 28 December 2017 - 08:34 PM
Yeah, that would work. Plus it doesn't need to look perfect, just needs to work to hold the servo steadily.
