Gulf Oil
Posted 23 December 2017 - 01:41 AM
Posted 23 December 2017 - 03:07 AM
Posted 23 December 2017 - 04:26 AM
Hi i been looking at Gulf Max Plus 20W-50 - 4ltr i know Valvoline is the best just rebuild engine just one some too bed the engine then changing go valvoline anyone just gulf max plus?
I'd suggest a lighter Oil. I use a 15W40;-
http://penriteoil.co...ASAAEgKImfD_BwE
You only want to use it for about the first 200 miles or so, but no more than 400 miles.
What ever you use, be sure it isn't friction modified or a synthetic.
Posted 23 December 2017 - 09:41 AM
I think Millers oils are good and pretty widely available, they do one especially for the Mini with its combined gearbox. I agree with Nick I think running oils are far more relevant on large unstressed engines that run the risk of the bores glazing up before the machines parts have bedded in properly (something like a large V8). When you are running a Mini in you struggle more not to work the engine too hard with modern traffic speeds, rather than work it hard enough.
Posted 23 December 2017 - 11:51 AM
when using any type of oil - also consider the gearbox & a quality oil filter
also consider there are fake oil's about - so if it is un usually cheap - dodge it
http://www.automotor...ssia-87039.html
this has happened in several country's
how you are supposed to tell the real one , I don't know
Edited by sledgehammer, 23 December 2017 - 11:54 AM.
Posted 23 December 2017 - 05:02 PM
Posted 23 December 2017 - 05:22 PM
Posted 23 December 2017 - 05:49 PM
With oil for the classic Mini there are two questions which need to be asked:
1. It is a mineral oil of the correct viscosity (2050 for a manual and 10w40 for an automatic.
2. Does it have a suitable level of zing - the ZDDP level.
If both are OK then it is fine to use. If they are not both OK then steer clear.
Posted 28 December 2017 - 12:41 AM
Although having some zing in your mini is good, what the gearbox really needs is some zinc!
Edited by timmy850, 28 December 2017 - 04:52 AM.
