Steering Wheel Shroud Removal
Posted 14 December 2017 - 03:27 PM
Posted 15 December 2017 - 12:58 PM
Posted 15 December 2017 - 04:40 PM
Posted 16 December 2017 - 12:59 AM
Will make a drawing if you like?
Posted 16 December 2017 - 08:58 AM
Posted 19 December 2017 - 06:37 PM
Well, the cowl is off! I took off the airbag (making sure that the battery was disconnected) and removed the steering wheel.This revealed the two plastic clips holding the top end of the two halves of the cowl together. The 3 screws securing the underside of the cowl had already been removed, so I used a small flat blade screwdriver to depress the 2 plastic clips and gently pulled the 2 halves apart. The clips parted and the cowl came apart.....but as you can see from the pictures below, the clips have really suffered from the removal. The stress fracture visible in the top picture has happened despite my taking a lot of care to not apply any undue force to the plastic....and as far as I'm aware, nobody has ever tried to remove the shroud before.
I shall have to come up with an improvised fixing method for the lower section when I refit the shroud......It seems that this is almost a "once only" type of fitting and that damage on removal is almost inevitable.
