Just trying to upload some photos, sorry if blank!
#16
Posted 30 April 2018 - 07:46 PM
#17
Posted 30 April 2018 - 07:56 PM
Before and after.
#18
Posted 30 April 2018 - 08:03 PM
#19
Posted 30 April 2018 - 08:04 PM
#20
Posted 16 December 2018 - 05:17 PM
mini cooper 023.JPG 50.45K
3 downloads
Does anyone have the same poor fitting panels as me? Everything heritage, Rear apron fine on one side, 4-5mm out the other, same with l/h wing, r/h fine.
#22
Posted 16 December 2018 - 05:23 PM
mini cooper 024.JPG 30.13K
3 downloads
3 downloads
So I cut a v out and added some metal.
#24
Posted 16 December 2018 - 07:08 PM
Yep! that's how they were built 40/50 years ago, to be in tolerance meant could it be hammered, pushed, pulled into place and it was fine. There was some old Pathe film's of the mini's being built on the Longbridge production line, the complete side's were clamped at the front of the sill and at the rear then spot welded up. Your repairs are looking good so far.
#25
Posted 16 December 2018 - 08:42 PM
Thank you, I have used no filler at all yet should only need a little on weld joints, I'm trying to get as original as possible, Do you know if the floor sound deadening /bitumen material is available or an alternative?
#26
Posted 21 December 2018 - 07:09 PM
Progress
Posted 21 December 2018 - 07:26 PM
Sorry, posts are a little haphazard! trying to work out attaching photo's, I have got most welding completed now, rear valance to do then attach battery cable channel to floor, It needed to be moved to allow heat shield studs in correct position for spi. also attach studs for fuel pipe brackets, Going to gravitex floor then paint body colour (black)
I'll get more photo's soon.
Mike.
#28
Posted 14 January 2019 - 08:22 PM
#29
Posted 14 January 2019 - 08:25 PM
Gravitex on floor before paint and perhaps a little premature but just collected re-upholstered seats.
#30
Posted 07 July 2019 - 08:59 AM
Also tagged with one or more of these keywords: rust repair
Mini Technical Sections →
Bodywork, Paint and Detailing →
Wheel Arch Repair For MotStarted by adman020 , 21 Jun 2024 ![]() |
Non- Genuine Door HingesStarted by CBJ805T , 09 Jun 2024 ![]() |
Where To Start - Rear EndStarted by OzKopite , 03 Mar 2024 ![]() |
Mini Specialist For Welding -South East/south WestStarted by s2ulk , 20 Oct 2023 ![]() |
Wheel Arch/boot Floor Repair HelpStarted by austinmayfair85 , 10 Aug 2023 ![]() |
