Cutting Compound
9 replies to this topic
#1 1984mini25
1984mini25
  • 8,784 posts
Posted 04 December 2017 - 05:56 PM
Using Halfords as an example as I know most stuff is cheaper online, but I can’t really be arsed with having to wait a few days for delivery each time.
Is this product basically the g3 rubbing compound that was in the yellow bottles in different packaging?
http://www.halfords....ver-paste-150ml
As I have a few areas I need to flat off with 2000 wet and dry and polish back up, although I might just settle for Halfords own rubbing compound.
#2 1984mini25
1984mini25
  • 8,784 posts
Posted 22 December 2017 - 09:01 PM
After doing a little digging it turns out that Farecla do a range of different products, witch all do different things under the same G3 name. So the Halfords G3 is just a scratch remover and not a cutting compound.
So any recommendations on a cutting compound for polishing up by hand, after flatting with 2400 wet and dry.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 22 December 2017 - 09:55 PM
Polishing by hand is bloody hard work so really i would get a electric mop. Anyway this is the G3 i used
https://www.amazon.c...ords=farecla g3
followed by this but in 1kg
http://www.theultima...0MaArP1EALw_wcB
My mop by the way is a Silverline multispeed using these waffle pads
https://www.ebay.co....73710387&crdt=0
#4 1984mini25
1984mini25
  • 8,784 posts
Posted 22 December 2017 - 10:10 PM
I know polishing by hand is hard work :P
I do have a mop, but I only need to do localised areas that need further attention (masking tape lines, dull/rough patches, scratches, overspray etc) on  panel edges, doors shuts etc, that can't be polished with a mop.
#5 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 December 2017 - 08:51 AM
In that case then use the products I posted, use a decent microfibre cloth to buff up. The S17+ could be used on its own to be honest as I have done in the past and it will pop as my pictures of Paddy will attest to. The G3 being a bit more old skool will however take out any heavier scratches to start with, then follow with S17+.
#6 1984mini25
1984mini25
  • 8,784 posts
Posted 23 December 2017 - 12:30 PM
So the bodyshop grade G3 is still the stuff to use, even though it is a bit old school.
Just a pain its back to ordering online again, as the nearest bodyshop supplier no longer has a trade counter.
Although you'd just have to look at the pics in my project thread to see that, apart from the issues I've highlighted, one thing the paint isn't lacking is shine. Although the pics really don't do it justice.
#7 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 December 2017 - 12:48 PM
Well i can only go by my results with everything
#8 1984mini25
1984mini25
  • 8,784 posts
Posted 23 December 2017 - 02:05 PM
Ah, but that's a solid dark colour, I'm working with polishing a silver base with clear...
#9 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 23 December 2017 - 04:14 PM
I like 3m finnesse
#10 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 December 2017 - 06:23 PM
In that case stick with the S17+, thats what I use on my daily and the wifes car. Both metallic black with Lacquer. The good thing about it is the way it breaks down ends up like a normal polish. Then wax. G3 is more old school whereas the S17+ is a new product that was recommended by a detailed on this very forum. Been using it for a while and happy with the results. I have no doubt there are far superior products out there but for the price Im happy.
Like Shift I also use 3M products as well, Polish Rosa is very good as well as the Finese.
