I'm just about to start dry building my A+ 1293, I've had the block bored out and bought these pistons made by Nural. http://www.minispare.../P21253-20.aspx
I've been doing some measurements of the bore with telescopic gauges and I'm getting 71.12 (2.8") which is the correct size for 1293cc. Measuring the pistons at the largest point below the rings are measuring 71.08 (2.798") giving a difference in diameters of 0.04mm (1.5 thou)
i've read a few threads and looks like the gap should be 0.076mm ( 3 Thou), Is this what it should be? As to me 0.02mm clearance "each side of the piston" doesn't seem like enough, Especially when heat is added to the equation?
Just for added info the top of the pistons (above the rings) measure 70.4mm (2.77"). Stamped on the top of them is 87-524107-00 + 0.020 71.02 sp 0.03 HVG.
If the clearance sizes I've got are not enough whats the best way to resolve it?
