You literally seem to be doing the all the same rear panels as I will have to do very soon. Cheers for the pics etc.
Clubby Rescue
#31
Posted 04 December 2018 - 06:48 AM
#32
Posted 30 December 2018 - 06:52 PM
yeah minimissions, most minis of this era are going to need the same panels replacing
been busy last couple of days
#34
Posted 23 February 2019 - 08:56 PM
Looking good, very impressive.
#35
Posted 17 March 2019 - 04:04 PM
right, after i've shimmed the balljoints, changed the steering rack gaiter and renewed the knuckle joint rubber, put some original wheel studs back on time to look at the passenger side
that is a gap between the A panel and the flitch panel
qucik tickle with the grinder and the A panel is off, it wasn't folded around the flitch panel and you can see the return for this was hammered flat, hence the gap
one thing i've noticed is there's no flat washers either side of the bush on the shocks, these are koni's, the metal sleeve must be too big as there isn't enough room for a washer either side, does anyone else have koni shocks and this problem?
#36
Posted 21 July 2019 - 06:46 PM
painted the shell in epoxy primer today, inside floors, rear seat, boot floor, rear valance will be done in raptor
#37
Posted 22 July 2019 - 08:36 AM
Looking very nice - what's the final colour?
#38
Posted 17 August 2019 - 06:28 PM
it's going to be yukon grey with a black roof
#39
Posted 17 August 2019 - 06:51 PM
so time to assess the bootlid, bonnet and doors, stripped all back
badge holes welded up along with a random hole and had to strengthen the hole for a boot mounted spotlight
bonnet
the doors already had door bottoms and skins fitted, i had already sourced a passenger door as i wasn't happy with the door now to look at the drivers
in step mr blue who i got from a mate, needs a bottom and skin
haven't done a door bottom before as i've always been able to source a good door only skinned external hinge doors before
mr yellow only requires a flange instead of the whole door bottom and i'll fit this tomorrow, paint the frames in epoxy primer before fitting the door skins
#40
Posted 24 August 2019 - 08:03 PM
door frames painted in epoxy primer and a bit of tiger seal on the door frame before dropping onto the door skin which was fitted with a sound deadening pad
i was surprised about heritages primer/E coat flaking off on the flange, i don't remember this happening before when doing door skins
#41
Posted 29 September 2019 - 11:13 AM
painting is done, almost
#42
Posted 03 January 2020 - 06:49 AM
O wow she is stunning! I have just gone back and looked through your thread nice work
#43
Posted 13 April 2020 - 02:13 PM
not far away now
Edited by hardtop, 13 April 2020 - 02:19 PM.
#44
Posted 13 April 2020 - 03:48 PM
Love the rear end of this car! That spotlight on the boot lid is stylish!
Edited by Vinay-RS, 13 April 2020 - 03:49 PM.
#45
Posted 03 May 2020 - 09:30 AM
just got to grease the balljoints, top and radius arms, sort the dash, gear knob front carpet, and the battery strap, front number plate and its ready for a spin
