Thanks Neil, I will try it out, if it doesn't work, then at least i tried.
Clubby Rescue
#16
Posted 19 December 2017 - 08:28 AM
#17
Posted 14 January 2018 - 05:21 PM
slight problem with the new floor, not pressed properly where the dogleg is on the heelboard
also the rear mountings for the subframe is out (the floor is upside down)
lining up the subframe before welding (well 3 mountings!)
and its in
#18
Posted 14 January 2018 - 06:32 PM
Great start, gonna follow this as my own needs a roof skin also
#19
Posted 15 January 2018 - 09:23 PM
sorry i've already done the roof and i didn't take any photo's :S
#20
Posted 22 January 2018 - 06:47 PM
back panel on today
#21
Posted 23 January 2018 - 06:47 AM
Nice work this is looking nice and solid again...
#22
Posted 15 February 2018 - 09:14 PM
one side done, one to go
#23
Posted 16 February 2018 - 01:02 PM
Nice progress on this :)
#24
Posted 24 February 2018 - 05:19 PM
wheel arch in, should have the rear quarter on tomorrow
#25
Posted 06 March 2018 - 03:35 PM
now the weather's been a bit better today
only the battery box and rear valance to go
#26
Posted 02 September 2018 - 06:20 PM
right painted my other car, back to the clubby, next on the list is the drivers side A post, cut off the A panel, its gonna need some work!
the flange that the is on the A panel can't be bent around and the flange was hammered flat against the A post, so cut it all out and start again, the passenger side is the same so thats going to be replaced as well, least the air vent is actually bolted/screwed to the inner wing unlike the drivers side
Edited by hardtop, 02 September 2018 - 06:28 PM.
#27
Posted 03 September 2018 - 05:42 AM
This shell is coming along nicely! some big panels defo make the difference in the build...
#28
Posted 04 September 2018 - 12:01 PM
Looking great. Im going to have to something similar to my Clubby.
#29
Posted 02 December 2018 - 06:30 PM
knuckle joint rubbers lasting well i see, these were brand new, just clean up original ones if possible is my advice
cut out some rust, seam sealer, weld and filler
that's all i can do until i get a new top door hinge, as the one on there has been modified, rest assured the rest of the A post will be removed once i know where the flitch panel is going
#30
Posted 03 December 2018 - 06:57 AM
Gonna take some more months to modify the whole lot. Good luck with that!
