Straight Cut Gear Conversion
Best Answer happydude2012 , 12 November 2017 - 03:57 PM
actually guys, ill take your advice and let it alone. I like being able to hear.
Thanks all very much for your guidance.
Go to the full post
17 replies to this topic
#1 happydude2012
happydude2012
  • 332 posts
Posted 12 November 2017 - 08:13 AM
Stupid question alert.
I have a standard A+ gear box with helical gears. (4 speed)
Is it possible to buy a straight cut kit (minispares) which i could switch out for my old helical set up or would i need a complete new box?
forgive the utter stupidity of this question if your a bit of a pro.
#2 Spider
  • 14,836 posts
Posted 12 November 2017 - 08:57 AM
For what it's worth, I think most of us consider the only stupid question is the one you don't ask.
Yes, most SC Gear sets fit stock gearbox cases.
#3 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 12 November 2017 - 09:23 AM
Some kits are below. You'd bank on doing a complete gearbox refurb at the same time. Some sets are "Close-Ratio" which means a smaller gap between gears
http://www.minispare...ts/C-STN39.aspx
http://www.minispare...ts/C-STN77.aspx
You can also get SC drop gear sets
#4 happydude2012
happydude2012
  • 332 posts
Posted 12 November 2017 - 09:34 AM
whats the difference with "drop" gears and "normal"
#5 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 12 November 2017 - 09:48 AM
Drop gears transfer the power from the crank (via the clutch) to the gearset. Helpful link here: http://www.minimania...w_they_work_864
Drop gears:
http://www.minimania.../drop gears.jpg
Gearset
http://www.minimania...th/main box.jpg
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 November 2017 - 12:55 PM
If you're asking what's the difference between straight cut drop gears and normal drop gears (helical), straight cut drop gears are ear bleedingly noisy, normal ones aren't.
#7 happydude2012
happydude2012
  • 332 posts
Posted 12 November 2017 - 12:59 PM
i use this car for daily driving - the interior is not sound proofed at all, its bare metal - in your opinion do you think that straight cut gears a **** idea?
#8 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 November 2017 - 02:18 PM
I've recently replaced my straight cut drops with helicles and the difference is amazing. Straight cuts are ok if you have a weekend warrior but no good without ear plugs for every day use.
#9 nicklouse
  • 18,574 posts
Posted 12 November 2017 - 02:21 PM
in relation to your other questions yes it is totally the wrong thing to consider.
more noise and more revs for the same speed.
#10 Cooperman
  • 23,276 posts
Posted 12 November 2017 - 02:52 PM
Straight cut gears are for competition cars where the cam only gives power over a relatively narrow band (like from 4500 rpm to 7000 rpm) and close gear ratios are needed to keep it on the cam combined with a low final drive ratio to enable it to pull away in 1st without a lot of clutch slipping.
On a road car it is far from ideal as the low final drive would mean high revs at normal cruising speeds giving more noise and higher engine wear.
#11 Ethel
  • 25,919 posts
Posted 12 November 2017 - 03:20 PM
They're mainly straight cut because it's too expensive to make them helical, though straight cut gears are a little bit more efficient. The gear ratios are the reason to change.
#12 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 12 November 2017 - 03:21 PM
Depends on if you like wearing earplugs or not...hahah
SC drop gears are generally very noisy and not needed for the road.
I used to drive with SC box and drops on the road and track, after an hour had a headache, earplugs are a solution, even with a helmet on. The female of the species generally hate the noise too. On quiet early mornings SC drops can be heard a mile away literally, even over the growl of split 45 webers.
Personally I love the sound of a SC gearbox, the whine is perfect, and puts a shiver up my spine when heard at distance.
Like many things Mini its down to personal choice, opinion and experience. If you can get a ride in one first it helps, if not try youtube
#13 happydude2012
happydude2012
  • 332 posts
Posted 12 November 2017 - 03:32 PM
well i love the sound, my late dad has straight cut on his hillclimber, but i cant remember being in it for long, apart from one time down the motorway, but no headache.
#14 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 12 November 2017 - 03:45 PM
You need to get a ride in one for a reasonable distance at a reasonably high speed otherwise you'll end up selling the idea to yourself without fully understanding how unpleasant the pitch of it can become.
#15 happydude2012
happydude2012
  • 332 posts
Posted 12 November 2017 - 03:55 PM
understood, and your most likely completely correct - i have to commute in this car, its not a weekender or show car.
I love the idea but i can imagine its going to do my head in.
