![Photo](https://secure.gravatar.com/avatar/7f8c9ab8485b1b3858c04080ebb335d7?s=100&d=https%3A%2F%2Fwww.theminiforum.co.uk%2Fforums%2Fpublic%2Fstyle_images%2Ftmf%2Fprofile%2Fdefault_large.png)
Mounting Bucket Seats To The Floor
Posted 07 November 2017 - 09:39 PM
Also does anyone know how far back the pre built subframes tend to go as if they give enough extra room I might just go with them, but would prefer to floor mount them just due to the extra head and leg room being much better
Glen
Posted 07 November 2017 - 09:47 PM
depends on usage and what mounting you are going to use.
add metal and drill holes.
Posted 07 November 2017 - 09:59 PM
It's only for road use so don't need to pass any checks or anything, in terms of mounting I was going to just use the standard side brackets that come for the actual seats, and just fabricate or buy something if there's some sort of kit to actually mount them to the car (planning on getting sparco sprints or cobra Monaco pro's depending on what's cheaper at the time really)
Posted 07 November 2017 - 10:54 PM
I'm using a seat similar to a sprint, I cut the top bits off the original seat brackets then welded 3mm plate to that so its flush with the crossmember, then welded some more 3mm together to make a stand for the rear seat mounts
Edited by Will16, 07 November 2017 - 10:54 PM.
