Ported Head
Best Answer timmy850 , 10 November 2017 - 12:00 AM
It's not too tricky really!
For more power from the head you want:
Bigger valves
Better port flow (reshaped and/or ported)
Correct compression ratio (measure combustion chamber and skim if necessary)
De-shrouding combustion chamber
BUT don't get the ports "polished" shiny smooth. This will reduce performance
Go to the full post
Posted 07 November 2017 - 09:27 PM
Posted 07 November 2017 - 09:33 PM
you dont want the ports polishing.
what casting?
Posted 07 November 2017 - 09:37 PM
Posted 07 November 2017 - 09:42 PM
The ruff grinding on the ports help the air and fuel to mix better.
The 295 or 206 heads are the ones to have modified, the 202 or the cam 4810 have smaller valves so not much gain.
You will prob need the head skimming to raise the c/r depending on the pistons you have.
In all honesty a 1275cc lump will be the best power for the £££ The 1100cc isnt the best lump to modify. But some did come with the 295 head. A better cam will see more power output.
Posted 07 November 2017 - 09:59 PM
With a 1098 engine you are better off seeking more mid-range torque rather than out-and-out top end power. The 1098 will not rev like a 998 or a 1275. You will need to change the cam to get the best results, but something like a 266 or Evo001 might suit well. There are other options you can consider, but avoid any cam which makes peak power at anything over about 5600 rpm as you don't want to rev a 1098 to anything much over 6000 rpm.
For the modifications to the head, you don't want or need to actually polish the inlet tracts. What should be done is to remove most of the valve guide bosses, clean up the short-side radius into the inlet valve, open up the exhaust tracts to reduce 'pumping losses' and, most important, grind out around the valves to de-shroud them and enable the gases to flow in and out more easily.
After doing that you MUST measure the sizes of the combustion chambers, calculate the size you need to get the compression ratio to what you want (probably about 9.75:1 for a 1098) then get the head skimmed to suit.
As for valve sizes this will be determined by which head casting you have, what valve sizes are available 'off the shelf' and whether you are prepared to have larger 1275 valves machined down to suit if the optimum sizes are not available.
Have a read of David Vizard's book ''How to Modify the A-Series Engine'. It explains in detail all the things mentioned by me and others on this thread.
Posted 07 November 2017 - 11:40 PM
I had my 202 head modified to suit a 1098 engine build. You might not need to get as much work done depending on the spec you are aiming for.
(27.2mm / 1.07" exhaust valves, 31.75mm / 1.25" inlet valves, Unleaded exhaust seats, valve guides, Combustion chamber & port work)
Cavler ST have some small bore head combinations listed on their website. You can see the valve sizes available and what kind of work is done to them.
http://www.calverst..../cylinder-head/
Posted 08 November 2017 - 10:11 AM
Posted 08 November 2017 - 10:17 AM
Posted 08 November 2017 - 10:20 AM
Posted 08 November 2017 - 08:51 PM
It's currently on the shelf as I've got the engine and gearbox reassembly to do first. It will be much better than the tired old 998 in the car now. I'm aiming for around 70hp
Posted 08 November 2017 - 10:36 PM
Posted 08 November 2017 - 11:32 PM
Over here the 1100 engine had the 202 head standard. It can be a better starting point for modifications as the valves and ports are slightly bigger
Posted 09 November 2017 - 12:47 AM
Regards
Phil.
Posted 09 November 2017 - 09:09 AM
Posted 09 November 2017 - 10:04 AM
Through skimming?
No. The chamber needs to be shaped/cut back by hand (or CNC if you're rich) to move the chamber walls away from the valve to reduce the shrouding effect.
Phil.
