Brake Master Cylinder Rebuild
brakes
Best Answer Spider , 28 October 2017 - 05:53 PM
There were three different shuttle pistons (19 in the drawing above) used during production. The one in the cut-away drawing is the early type and it looks like you have the last type. They supply O Rings in most kits to cover all types.
Go to the full post
2 replies to this topic
#1 bobcrumble888
bobcrumble888
  • 12 posts
Posted 28 October 2017 - 01:25 PM
Hello,
A 1979 1275gt Clubman.
I have stripped down my brake master cylinder to replace the seals. Not the easiest of task when trying to read a Haynes Manuel that doesn't have a enough detail to be confident in what your doing if you haven't done it before. But anyway i managed to strip it right down without major issue...
Apart from, the Pressure Failure Switch piston was very tight to get out. Eventually i managed it but in the process pulling it out through some of its O-rings. now my issue is putting it back together.
Not sure what order the O-rings go in and the repair kit i bought came with to many O-rings.
I've tried to supply the best pictures possible.
Any help would be great.
Attached File  1.jpg   55.94K   1 downloads
Note: Cap head bolt shouldn't be there, thats when the electrical connection should be but i broke it  :whistling:
Attached File  2.jpg   55.65K   0 downloads
Attached File  3.jpg   55.06K   0 downloads
Attached File  4.jpg   55.28K   0 downloads
Attached File  5.jpg   59.06K   0 downloads
Note: Piston should be facing other direction.
Attached File  6.jpg   58.37K   1 downloads
Attached File  7.jpg   48.49K   1 downloads
#2 Spider
  • 14,838 posts
Posted 28 October 2017 - 05:53 PM   Best Answer
#3 bobcrumble888
bobcrumble888
  • 12 posts
Posted 29 October 2017 - 11:51 AM
Awesome! Exactly what I was looking for! Wasnt expecting to get an answer so quickly. Lovely stuff
Also tagged with one or more of these keywords: brakes
