1969 Mini Cooper S @ Mill Road Garage Isle Of Wight
289 replies to this topic
#76 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 November 2017 - 08:07 PM
Thanks gents :-)
#77 I hate Brian
I hate Brian
  • 782 posts
Posted 22 November 2017 - 06:55 AM
Excellent work Ben!
#78 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 November 2017 - 06:41 PM
Continuing on from yesterday, I finished the welding on the r/h wheel arch. It's now at the stage where it will be left until prep time.
A splash of paint to protect for the time being
As you can see, there is quite a filler edge above the repair. I don't think there is anything to gain by stripping that away so ill feather some into the repair come prep time.
I was keen to cut the filler neck hole next so made a template out of the old rear panel
The plan is to use an air nibbler inserted through a pre drilled hole, nibble the bulk out and finish with a carbide burr. I decided to have a practice on a scrap rear panel.
I'm quite pleased with that.
Sadly, I didn't get to cut the hole on the actual car due to inspiring my work colleague with my method.
He has been fabricating an adapter for his cooker hood and needed to cut out a round hole. Unfortunately, the steel he is using is much thicker than what I am working with and the nibbler broke part way through.
Ill get another and cut it when it arrives.
Instead, I decided to repair the other quarter panel.
This side should have only needed a small piece adding but after cutting it out, it seems it wasn't to be
Lots and lots of filler.
I knew there was filler in it but hadn't realised there would be so much. On closer inspection, it is up to 1/2" thick in places across the radius of the arch.
What I believe had happened was when it had in the past wide arches fitted, it had taken a clout and tucked the arch in.
Whoever repaired it opted for a filler repair, i guess to save taking the fuel tank out.
Anyway, It needed to come out so using a block of wood, I knocked it from inside and the filler fell off
To repair the arch, first I need to 'rough out' the panel. This is to get the bulk of the dent out and restore the basic shape
As you can see, there are plenty of high and lows which ill address next but the panel is back to a good profile
I have reshaped the front half of the arch now picking up the low spots and flattening out the highs so it looks more like this
Still a fair way to go but it's coming along.
More tomorrow.
cheers
Ben
#79 evoderby
evoderby
  • 92 posts
Posted 22 November 2017 - 06:57 PM
Great job, thanks for sharing all of this....very insightful! On the subject of cutting a hole for the right hand tank, tell me what size (mm) you need and I'll send you the correct holesaw and arbor. FOC.
#80 JXC Mini GT
JXC Mini GT
  • 842 posts
Posted 22 November 2017 - 07:01 PM
Great work Ben, when I saw the Mini in the flesh a few weeks ago I would never have guessed there was so much filler hidden behind what looked like a good condition rear quarter.
#81 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 November 2017 - 07:07 PM
That's very kind of you. Thanks so much.
I believe that the diameter is 70mm but ill double check tomorrow.
Ben
Edited by Ben_O, 22 November 2017 - 07:10 PM.
#82 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 November 2017 - 07:09 PM
It is a shame John but it is better to find it now and remove it before it gets painted again.
Body filler has it's uses but it is not designed for this type of repair or to be used to this depth.
Ben
#83 evoderby
evoderby
  • 92 posts
Posted 22 November 2017 - 07:47 PM
Ben
Cool, if you let me know before 14pm I can have it with you on Friday.
#84 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 23 November 2017 - 02:08 AM
Do I count 8 layers of color/primer/filler from the metal? Crikeys!
#85 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 November 2017 - 08:54 AM
something like that!
#86 johnR
johnR
  • 2,297 posts
Posted 23 November 2017 - 09:45 AM
Must be rather daunting making the first cut into what looked on the face of it to be a pristine car!
#87 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 November 2017 - 02:00 PM
You are right there.
It's a shame to start sanding back the recent paint but once it's all done, it will be a better car for it.
Ben
#88 DeanP
DeanP
  • 499 posts
Posted 23 November 2017 - 07:00 PM
I can't believe you've managed to planish those dents out!
Edited by DeanP, 23 November 2017 - 07:00 PM.
#89 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 November 2017 - 09:43 PM
Cheers.
It's virtually done now but I haven't had time to do an update today.
Ill pop it up tomorrow.
Ben
#90 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 23 November 2017 - 10:26 PM
The  rear quarter panels of my clubman had the "been lowered too much" dents on the forward edges or the wheel arches on both panels. I had to hot shrink a large part of both panels to remove the stretched metal, I didn't hammer out all the little ripples and dents but the amount of filler required was minimal compared to simply walloping it all inwards then firing up the cement mixer! Top job you're doing there, looking forward to the next instalment!
