1969 Mini Cooper S @ Mill Road Garage Isle Of Wight
289 replies to this topic
#241 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 January 2018 - 07:55 PM
Ben,do you recommend that stuff for a regular Mini? Does it reduce the noise as well.
Keen to get sound dampening materials and quieten my Mini.
It is similar to the material that was fitted to Mini's in the factory and is suitable as an anti drum. It stiffens the floor pan up and takes out most of the drum and boom that a bare floor would give.
It does keep road noise down to an extent but proper carpet underlay is more suitable for that.
This car now has both so it should be a marked improvement.
It's still not going to be quiet in there but will be better than it was before
Thanks, Ben :) does minispares stock the stuff? I need to get the firewall padding, the bonnet padding and if I get the kit with the interior padding too, it would be nice to get this material too.
I'm not sure mate.
Mine comes from my paint supplier. I have always used the same one because it forms nicely. If it aint broke, dont fix it and all that.
#242 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 23 January 2018 - 07:58 PM
Thanks. I'll have a look and perhaps contact Simon directly. Looked really good in the photos you shared.
#243 panky
panky
  • 1,853 posts
Posted 23 January 2018 - 08:42 PM
I used this all over my Morris Traveller and it did make a difference, the biggest being inside the doors. You can get it pretty cheap on Ebay (cheaper than Silent Coat) have a search for sound deadening in car parts.
Here's an example
https://www.ebay.co....pQAAOSwbsBXpEoe
The car looks fantastic Ben, especially when all the rear end trim went back on :mrcool:
#244 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 January 2018 - 08:52 PM
You will need a hot air gun to apply it and then either a small hard roller or finger tips of steel.  I have the latter..
When doing floors, you need to work it into the grooves as you go so you don't stretch it. I peel back the backing a little at a time to stop it sticking before you are ready.
#245 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 January 2018 - 08:20 PM
More rebuilding today.
I refitted the exhaust system, installed the underlay and the parts of the carpet that needed to be glued in as well as a full compliment of new rubber bungs throughout the floor.
I also refitted the steering column, dash cards and throttle pedal.
Then once that was done, I refitted the wheels and lowered it back to the floor
Then in went the back seat, carpets, rear quarter trims and bin liners
Then I finished inside the boot by popping in the spare wheel but not before filling the fuel tank to check for leaks and replacing the entire tank breather pipework as only one tank was vented with a brittle plastic tube before I stripped the car and there was an alarming smell of petrol inside.
Now we have a rubber tube from each tank joining to another by a T piece which now goes outside of the car underneath.
I also connected up the battery to check everything was working correctly which it is
Then I fired up the engine to check everything was ok there which it was although the engine is not running very smoothly. It seems to be choking itself so needs setting up.
Ill do that tomorrow.
Finally, I refitted the handbrake lever which I repainted and the kick trims on the inner sills
And then popped the front seats back in along with the seatbelts.
I also refitted the sun visors and rear view mirror and then the headlining.
I finished up by diagnosing the non-working interior light which Ill repair tomorrow.
Ben
#246 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 January 2018 - 06:36 PM
The rebuild is now complete.
Both doors are bolted on
And the rear glass is fitted
The customer informed me that the interior light wasn't working so I diagnosed that and replaced some damaged wiring
All that is left is to flat and polish the paintwork and refit the side arch/sill trims and then it's complete.
There is some other minor mechanical work to do though not relating to the rebuild and I am going to try a genuine bonnet on it in place of the magnum one which doesn't fit well.
If the genuine one fits nice, ill paint and fit that
Ben
#247 miniireland
miniireland
  • 175 posts
Posted 26 January 2018 - 06:57 PM
Stunning work Ben it looks truly fantastic
#248 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 26 January 2018 - 07:19 PM
Absolutely incredible. Has to be my favourite colour combo, just looks so right. Definitely one of my dream cars.
#249 CityEPete
CityEPete
  • 3,920 posts
Posted 26 January 2018 - 07:49 PM
Someone's going to have a great summer whizzing around in that!
#250 panky
panky
  • 1,853 posts
Posted 26 January 2018 - 08:23 PM
Proper job :wub:
#251 Haygate
Haygate
  • 115 posts
Posted 27 January 2018 - 08:08 AM
Great work as always Ben.
#252 fiestaharry
fiestaharry
  • 295 posts
Posted 28 January 2018 - 02:41 PM
Love your work!
#253 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 January 2018 - 07:06 PM
Love your work!
Thanks!
#254 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 28 January 2018 - 07:59 PM
I am so bringing my S to you in the future!  Thank you for sharing your work.
#255 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 January 2018 - 08:31 PM
It's a pleasure :-)
    Bing (1)
