1969 Mini Cooper S @ Mill Road Garage Isle Of Wight
289 replies to this topic
#166 Jase
Jase
  • 1,166 posts
Posted 08 January 2018 - 03:28 PM
Ben, what make shears do you use to shape the metal and what gauge metal are you using?
Jason
#167 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 January 2018 - 07:12 PM
Jason
I don't tend to use shears or snips. I use mainly my air cut off tool with 1mm cutting discs or the 4.5" angle grinder with 1mm cutting discs
I use 0.8 generally for body panel bits and 1-1.2 for the more structural sections depending on what they are.
It's always best to measure the thickness of the metal on the panel you are repairing so that you can match the new steel to it
#168 miniireland
miniireland
  • 175 posts
Posted 09 January 2018 - 11:45 AM
Hows progress Ben
Simon
#169 blueovalcraig
blueovalcraig
  • 193 posts
Posted 09 January 2018 - 12:40 PM
Fantastic work as always!
#170 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 January 2018 - 07:25 PM
Hows progress Ben
Simon
I have been getting on with the prep work today.
I started with the N/S
This was the side that I pulled the thick chunk of filler out of the arch
I removed the various layers of filler and paint from the area and dressed out the shallow depression in the bottom of the quarter panel.
Then it got a thin layer of regular body filler to bring up the remaining low points.
That was then rubbed down and a thin layer of finishing stopper was applied
Which was then rubbed down
You can see in the pictures that I have done the step too but didn't remember to get any photos.
Ill finish the prep on the back and other side tomorrow and we will soon be ready for primer.
Ben
#171 Jase
Jase
  • 1,166 posts
Posted 09 January 2018 - 07:36 PM
Jason
Thanks Ben, I had enough of welding and panel replacement so decided to work on my current project. Feeling the itch for a TR6 next to do some work on. Your work is amazing and inspiring.
#172 Wild
Wild
  • 15 posts
Posted 09 January 2018 - 08:48 PM
My work colleague and I restored a TR6 two years ago that had been off the road for 30 years. It had already been painted however all the mechanical, trim, interior, exhaust etc need major attention. Got it finished and it looks lovely, I'd be very interested in hearing if you have one or are going to get one :D
Ben, your work is fantastic. I wouldn't hesitate to put any vehicle in for repair with you, your work is 2nd to none!  :highfive:
#173 Avtovaz
Avtovaz
  • 1,230 posts
Posted 09 January 2018 - 09:41 PM
ah, those murex welders are the best welders ive ever used! awesome...
thanks for the update mate. Looking good!
#174 miniireland
miniireland
  • 175 posts
Posted 09 January 2018 - 09:48 PM
Brilliant work as usual
#175 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 January 2018 - 04:56 PM
Sadly, only another small update today. I had to leave at 2pm for an emergency dental appointment after breaking a tooth.
Here is what I did get done though
First the other arch was sanded back as well as the C pillar joins
And a base layer of filler was applied
Which was then rubbed down and shaped accordingly
Before finishing off with the fine finishing stopper
Then I swallowed a brave pill and drilled the hole for the second tank
And then prepped the back end using a scotchbrite and palm sander with 320 grit discs
More prep tomorrow
Ben
#176 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 10 January 2018 - 05:34 PM
Sorry to hear about the tooth, how did you break it?
I think most will agree that you still get more work done in a day than almost anyone :D
#177 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 January 2018 - 05:51 PM
I broke it eating.
There was an old metal filling that had been in there over a root filling since I was a teenager and it decided to fall out and break the side of the tooth too.
It's now bodged up until next week when they will start working on a crown for it
Ben
#178 Marco1972
Marco1972
  • 822 posts
Posted 10 January 2018 - 05:53 PM
Oops double post
Edited by Marco1972, 10 January 2018 - 06:13 PM.
#179 Marco1972
Marco1972
  • 822 posts
Posted 10 January 2018 - 05:54 PM
Looking good mate
Bet you have this finished and be onto your next job well before mine sees the road
Ps I broke a tooth once bloody agony 😣
Hope it gets sorted
Mark
#180 evoderby
evoderby
  • 92 posts
Posted 10 January 2018 - 06:09 PM
Great progress Ben.....love the right hand side filler neck hole, that must have been a sweaty palms moment :-)
Look forward to seeing the body in a fresh coat of paint soon! Is the owner going for period straight from the gun finish or mirror smooth colour sand/polish?
Edited by evoderby, 10 January 2018 - 06:10 PM.
