1969 Mini Cooper S @ Mill Road Garage Isle Of Wight
289 replies to this topic
#151 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 December 2017 - 07:13 PM
Today was the final push for the panel work on this Mini and there was still lots to do.
First up, I welded in the crossmember end
And then the outer sill and jacking point needed to go on
There was an issue with the step. A replacement had been fitted previously and being a Magnum type step, the folds were wrong. I am sure some of you will be aware of this problem with those panels.
I can get the step to come over to meet the sill but only with the sill off. I could dress the sill in to meet the the step but I had noticed that the step sat in too far from the bottom of the door as this earlier picture shows
I'm not happy leaving it like that so...
I spot welded some washers to the step and intervals
And then used a slide hammer to pull the step over
It's not under any tension in the photo as I couldn't hold it and take the pic :lol:
But once held over, I clamped it up to get this
And then spot welded it
And now the door looks acceptable
I needed to spot weld the front edge of the sill to the step and the bottom of the A panel but it looked a bit suspect
I cleaned it back to reveal this
I decided to patch it up to give me something to weld to
Next up was the quarter panel
Once that was cut out, I had this
So I made up a new piece
Which I then trimmed up and clamped in place ready to weld
And then welded and dressed
I also spot welded the companion bin bottom to the floor, Repaired the front edge of the companion bin where it spot welds to the inner sill as well as welding up the jacking point to the outer sill.
No pictures but the same process as the other side.
Next, I dressed the weld seam where the new inner sill joins the existing floor and gave everything a spray up
The only panel work remaining now was the flitch repair. Unfortunately, I just ran out of time.
I need to empty the workshop tomorrow ready for the floor to be painted on Friday so I shall finish that last small repair in the new year.
The last thing today then was to get the car rolling. I put on the wheels, dropped it to the floor and then took some pics
And that is the last update of 2017.
Happy Christmas everyone  :xmas:
Ben
#152 panky
panky
  • 1,789 posts
Posted 20 December 2017 - 07:19 PM
And a happy Christmas to you :D  - I expect you'll want to take the whole of Christmas day off :shy:
#153 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 20 December 2017 - 07:42 PM
Great work Ben, Happy Christmas to you and all the team at Mill Road Garage. :xmas:
PS: I can see my Mini in the last photo and this will be the 2nd Christmas it has spent with you. :xmas:
#154 Marco1972
Marco1972
  • 822 posts
Posted 20 December 2017 - 09:32 PM
Great job Ben
Have a great Xmas and enjoy the break 👍🏻
#155 Avtovaz
Avtovaz
  • 1,230 posts
Posted 20 December 2017 - 10:13 PM
happy christmas mate, hope you have a good one ;))) thanks for the updates!
#156 CityEPete
CityEPete
  • 3,920 posts
Posted 22 December 2017 - 09:43 PM
I haven't checked in for a while, still excellent work and progress, I love it!
#157 Petrol
Petrol
  • 967 posts
Posted 22 December 2017 - 10:51 PM
Good work Ben as always.
Happy Christmas.
Pete
#158 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 December 2017 - 08:47 AM
Thanks Pete
Happy Christmas.
Pete
Happy Christmas to you too
Ben
#159 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 04 January 2018 - 12:16 PM
Read through this full thread, awesome work on this car, Ben. Looks great! If you don't mind me asking, what are your other Mill Road Garage build? Keen to read through all of them.
#160 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 January 2018 - 07:08 PM
Cheers Vinay!
The other builds can be found here
http://www.theminifo...l road garage
http://www.theminifo...-isle-of-wight/
And this one which will be continuing this month and is our own Mini
http://www.theminifo...and-rusty-mini/
Ben
#161 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 January 2018 - 07:18 PM
Happy new year everyone.
Time to get back on this Mini and get it ready for paint
The main bit left to do welding wise is the flitch repair
This is the area minus the bit I cut out last time
it's exactly the same process as the other side so first needs to be cleaned back
Then I needed to cut out a section of floor, toe board and some more of the inner wing
First is the floor pan piece
And then the flitch bottom which gets fabricated and tacked in place. I have also began spot welding some of it too
Next, the edge gets welded to the outer sill end
And then a Toe board piece gets made and tacked in
Then I can trim and fold the flitch bottom around the toe board repair and weld everything up fully
And then have a grind up
And we are done.
Time to remove the rear subframe then
There was a bit more welding to do once the subframe was removed that couldn't be accessed with it in so that is almost finished now too.
By the end of tomorrow, I should have the old underseal removed from the underside and some of the prep started.
Thanks for looking
Ben
#162 miniireland
miniireland
  • 175 posts
Posted 05 January 2018 - 11:40 AM
This is stunning work
#163 projectjordan
projectjordan
  • 88 posts
  • Local Club: southwalesminis
Posted 05 January 2018 - 01:29 PM
Cheers Vinay!
Ben
Awesome...that's my afternoons 'work' sorted
#164 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 January 2018 - 07:02 PM
Cheers Vinay!
Ben
There is another which I forgot to add
#165 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 January 2018 - 07:10 PM
Today has been spent on my back underneath the Mini scraping off the 1/4" thick underseal.
I don't have any photographs of the progress so far but will pop some up next week once I have finished.I also finished the last of the welding which was a couple of plug welds on the heelboard and welding on the rear slinging brackets.
Once I finish the underside, Ill get on with the prep.
Ben
