High Torque Starter Wiring.
Posted 23 October 2017 - 10:24 AM
Posted 23 October 2017 - 04:04 PM
Your 2 x thick brown wires will go on the "bolt" terminal, then you will need to put a spade connector on your white/red, which then goes on the "spade" terminal or trigger for the starter.
Andy
Posted 23 October 2017 - 06:58 PM
Posted 23 October 2017 - 08:09 PM
I think your large brown/red should connect to your "bolt." Previously on the solenoid there would have been a spade terminal that was commoned with the post that the other browns were bolted onto. So you will probably have to change the connector. The white/red is the trigger from the ignition.
Andy
Posted 23 October 2017 - 08:27 PM
Posted 24 October 2017 - 09:13 PM
Posted 24 October 2017 - 09:57 PM
The brown/red should be the operating wire. The ballast bypass (ignition) would be white/YELLOW. White/RED is the engine cranking feed from the ignition barrel. It would have gone direct to an inertia starter solenoid, but operates the starter relay that feeds the brown/red on a pre-engaged motor.
