I've got a crank that I found in the loft but don't know much about it, is anyone able to identify it?
It has "76 3" stamped on it
thanks
Posted 14 October 2017 - 03:36 PM
thanks
Posted 14 October 2017 - 05:35 PM
Don't know. you will have to measure the rod size and throw to work it out. It's been run but not much, it looks like the web at the clutch end was fouling the case somewhere? perhaps that's why it got taken out and wrapped!
Posted 14 October 2017 - 05:54 PM
Posted 14 October 2017 - 06:04 PM
http://www.farndon.com/ is probably the manufacturer but a 76.3 mm stroke ?
Posted 14 October 2017 - 08:50 PM
Well the standard 998 engine has a 3.0" or 76.2mm stroke, so I'm guessing a 998 crank.
Posted 14 October 2017 - 11:13 PM
Posted 15 October 2017 - 12:16 AM
Step on the rail looks like a 1275 though.
Would make 1195 cc. Intresting
The mains also look like 2".
Sub 1200 cc class ?
Posted 17 October 2017 - 01:40 PM
looks like a short stroke bilet 1275 crank,
73.5mm bore and 76.3mm stroke will give 1295cc
Mini Technical Sections →
Problems, Questions and Technical →
Air Conditioning For 1960 Mk 1Started by Oldkartracer , Today, 05:04 AM engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
