Removing Locking Wheel Nuts Without Damage - Without The Key
5 replies to this topic
#1 panky
panky
  • 1,790 posts
Posted 04 October 2017 - 07:06 PM
Ran into a problem when I came to do the tie bar bushes today - couldn't find the key for the locking wheel nuts >_< So I had to improvise. I know I'll fall over the key next week but the wheels needed to be off and the locking nuts un-damaged, so I came up with this idea.
Cut a short length (about 1") of 20mm copper pipe and slide it over the locking nut
It's a nice snug fit (this was an early attempt so it's a bit too short )
Take a 19mm socket and bash it on over the copper pipe. You will need to taper the end of the copper pipe slightly so it just fits inside the socket - but not much. The socket will push the copper pipe into the grooves in the nut and the soft copper wont cause any damage. Use gentle pressure to undo the nut with a T bar, ratchet of whatever - and it comes right off :D
I used the same piece of copper for all four locking nuts, but there wasn't much left of it at the end
It took a bit of experimenting to get the right size socket and this is obviously for the Rover 'Minilites' but it could work on other similar styled locking nuts.
#2 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 04 October 2017 - 07:38 PM
Great idea.....
Im off to change all my locking nuts now for a better more secure type LOL
#3 GT Jimmy
GT Jimmy
  • 1,641 posts
  • Local Club: S.U.N.M.C
Posted 04 October 2017 - 08:37 PM
Now everyone knows how to nick your wheels haha
#4 panky
panky
  • 1,790 posts
Posted 04 October 2017 - 09:04 PM
They would take one look at them and walk away shaking their head, not worth their time wasting a piece of copper :shy:
#5 jamesquintin
jamesquintin
  • 1,017 posts
Posted 05 October 2017 - 07:53 AM
I had the same issue. I just used the correct size socket, but one with the multiple ridges inside (not sure of the name) and cut 2 nails down to the length of the wheel nut, put them in the ridges on the nut and slid the socket over.
Came of as per normal and no copper was harmed in the process.
I also found the locking nut 2 days later  :highfive:
#6 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 06 October 2017 - 10:03 AM
The standard rover wheel nuts and locking nuts are potentially the worst thing I've seen made for a car. If you can find an alternative, I'd jump at the chance!
