Non Isocyanate 2K Paint
Posted 03 October 2017 - 01:28 PM
Posted 03 October 2017 - 02:23 PM
Had a look online recently myself, didn't find much useful information tho
Few mentions on online forums, one person reconed it was just very low Isocyanate and still dangerous, but didn't provide any information to back up that claim?
Posted 03 October 2017 - 03:20 PM
Posted 03 October 2017 - 03:32 PM
From what I can find it takes longer to harden.
Probably why there's not much info on it from professional bodyshops, not much use to them if it takes longer to harden.
Time is money and 2K paint gives a great finish, why bother with anything else.
There are also waterbased paints available, which I seem to remember need decent airflow to dry them?
Posted 03 October 2017 - 05:47 PM
My choice if not set up for 2k isocyanate would be
High build epoxy primer
Solvent basecoat
Upol 1k clear coat.
the none ISO hardener just sits on the shelf awaiting my next tidy up when it will be binned
Edited by Daz1968, 03 October 2017 - 05:48 PM.
Posted 03 October 2017 - 06:14 PM
I have tried the non ISO hardener from Jawel in primer, was really disappointed it needed thinning far more than recommended as the hardener is like gel, it doesn't harden as good as 1k primer and was terrible to sand. Then to top it off any application of high thinners basecoat over it caused it to soften and sink. Was so bad I bought an airfed mask to use the proper hardener.
Solvent basecoat
Upol 1k clear coat.
Thanks. Were you involved in the discussion on the mig welding forum? I found that today and the general consensus was as you have just said over 10 pages of discussion.
Posted 07 October 2017 - 10:02 AM
There are good non-isocyanate 2K paints.I use Chromabase from Cromax (formerly from DuPont, but sold to Cromax.) However, this line doesn't seem to be sold in Europe as far as I can tell.
It still has an activator, which is included with the reducer, but it's not isocyanate based. There is an optional isocyanate hardener (required for the paint to be warrantied for commercial work) but I've used it without the hardener on demanding surfaces like the nose of a car and it's held up well. It's a basecoat/clearcoat system (clearcoat required.)
Even though this line may not be available in some regions, it does demonstrate that good non-isocyanate 2K paint systems exist (Chromabase has been around for at least 15 years.)
Just go to your local automotive paint vendor who sells to local paint and bodywork shops, and ask them what non-iso 2K paint product lines are good. They have no real reason to steer you wrong. You can always take the line they recommend and do further research on it.
Posted 07 October 2017 - 02:48 PM
I have plenty of time to continue research though.
Posted 07 October 2017 - 06:43 PM
If the paint supply store sells only one brand, then their recommendations might be potentially suspect. Perhaps there's a shop that offers PPG, Glasurit, R-M, Sikkens, or Standox? These are some of the major names in auto painting worldwide. Do they even sell to home users in the UK and Europe?
Posted 09 October 2017 - 02:21 PM
LKQ coatings stock all of those brands, not sure if they sell to the public?
http://www.lkqcoatin...d-coatings.html
