Era Mini Turbo
227 replies to this topic
#106 mk1leg
mk1leg
  • 9,343 posts
Posted 19 April 2020 - 09:56 PM
hi  peeps not to much to report on today as I've been perplexed about the pin holes on the boot wheel well and decided to use 1mm aluminum and stick it down with Sicaflex its not for the purists but Im happy with the result I will fill and make good the edges
#107 mk1leg
mk1leg
  • 9,343 posts
Posted 20 April 2020 - 05:49 PM
hi.. peeps some more done today I filled and rubbed down etch primed ally and primed and applied a protective coat of black
applied some seam seal to back edge
#108 mk1leg
mk1leg
  • 9,343 posts
Posted 21 April 2020 - 07:21 PM
Hi..Peeps today effort I not a happy Chappy I ordered bottom door repairs from Minispares great service under these strange conditions any way what a load of rubbish these Magnum panels are Why Oh Why can't they make them with the Part that rusts the flange that the door skin attaches to I'm going to Bin these an they are useless
era%200203.jpg?width=1920&height=1080&fi
era%200204.jpg?width=1920&height=1080&fi
era%200205.jpg?width=1920&height=1080&fi
this is the Part of all door that go rusty not the Inside LOL
era%200206.jpg?width=1920&height=1080&fi
era%200207.jpg?width=1920&height=1080&fi
#109 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 April 2020 - 08:12 PM
Those magnum panels are bad.
I tend to fabricate new bottoms as they are straightforward enough and you can make just what you need.
#110 mk1leg
mk1leg
  • 9,343 posts
Posted 06 May 2020 - 10:03 PM
Hi..Peeps next update I removed front and rear subframes
era_0236.jpg?width=1920&height=1080&fit=
era_0235.jpg?width=1920&height=1080&fit=
then I tipped the shell on its side to work on the underside first I cleaned off all the wax protection
era_0244.jpg?width=1920&height=1080&fit=
era_0245.jpg?width=1920&height=1080&fit=
era_0246.jpg?width=1920&height=1080&fit=
era_0247.jpg?width=1920&height=1080&fit=
then I washed the underside with petrol
era_0248.jpg?width=1920&height=1080&fit=
era_0249.jpg?width=1920&height=1080&fit=
era_0250.jpg?width=1920&height=1080&fit=
era_0252.jpg?width=1920&height=1080&fit=
era_0253.jpg?width=1920&height=1080&fit=
then gave it a good sanding and etch primed underside
era_0254.jpg?width=1920&height=1080&fit=
era_0256.jpg?width=1920&height=1080&fit=
era_0258.jpg?width=1920&height=1080&fit=
next job is seam seal underside
#111 GraemeC
GraemeC
  • 7,438 posts
Posted 07 May 2020 - 05:59 AM
It’s in great condition under there!
#112 mk1leg
mk1leg
  • 9,343 posts
Posted 07 May 2020 - 07:06 PM
well new rear valance, boot floor repair, boot hinge repair, small repair left wheel well/arch wheel well was riddled with small holes but not bad
#113 mk1leg
mk1leg
  • 9,343 posts
Posted 07 May 2020 - 07:13 PM
todays effort apply seam seal and prime
era_0259.jpg?width=1920&height=1080&fit=
era_0260.jpg?width=1920&height=1080&fit=
era_0261.jpg?width=1920&height=1080&fit=
era_0262.jpg?width=1920&height=1080&fit=
era_0263.jpg?width=1920&height=1080&fit=
era_0264.jpg?width=1920&height=1080&fit=
era_0265.jpg?width=1920&height=1080&fit=
era_0266.jpg?width=1920&height=1080&fit=
era_0267.jpg?width=1920&height=1080&fit=
era_0268.jpg?width=1920&height=1080&fit=
era_0269.jpg?width=1920&height=1080&fit=
era_0270.jpg?width=1920&height=1080&fit=
era_0271.jpg?width=1920&height=1080&fit=
era_0272.jpg?width=1920&height=1080&fit=
era_0273.jpg?width=1920&height=1080&fit=
era_0274.jpg?width=1920&height=1080&fit=
era_0275.jpg?width=1920&height=1080&fit=
tomorrow is Raptor day
#114 mk1leg
mk1leg
  • 9,343 posts
Posted 08 May 2020 - 07:45 PM
Happy VE day peeps todays effort was to apply Raptor
era_0278.jpg?width=1920&height=1080&fit=
era_0277.jpg?width=1920&height=1080&fit=
era_0279.jpg?width=1920&height=1080&fit=
era_0276.jpg?width=1920&height=1080&fit=
as you can see I had run out of Raptor but I still need to tip it onto the other side to clean both wheel arches and get some more Raptor
#115 mk1leg
mk1leg
  • 9,343 posts
Posted 11 May 2020 - 06:06 PM
good evening peeps yesterday I Tipped the shell onto the other side to gain access to the parts not able to reach and rubbed it down and washed and etch primed and then applied seam seal and reprimed then I applied Raptor and I'm very please with the Product and the finish as never used this before
era_0280.jpg?width=1920&height=1080&fit=
era_0281.jpg?width=1920&height=1080&fit=
era_0283.jpg?width=1920&height=1080&fit=
era_0284.jpg?width=1920&height=1080&fit=
era_0285.jpg?width=1920&height=1080&fit=
era_0286.jpg?width=1920&height=1080&fit=
era_0287.jpg?width=1920&height=1080&fit=
era_0288.jpg?width=1920&height=1080&fit=
era_0289.jpg?width=1920&height=1080&fit=
next step is to refit fuel pipes and brake pipe and steering rack
#116 mk1leg
mk1leg
  • 9,343 posts
Posted 12 May 2020 - 09:32 PM
good evening peeps today's efforts first I rubbed down the black protection and applied body colour to engine bay then 2 coats lacquer
era_0290.jpg?width=1920&height=1080&fit=
era_0291.jpg?width=1920&height=1080&fit=
era_0292.jpg?width=1920&height=1080&fit=
era_0293.jpg?width=1920&height=1080&fit=
era_0294.jpg?width=1920&height=1080&fit=
then I tackled the steering rack I cleaned it and painted it stripped it doan and regreased it and fitted new gaiters and rod ends
era_0237.jpg?width=1920&height=1080&fit=
era_0238.jpg?width=1920&height=1080&fit=
era_0239.jpg?width=1920&height=1080&fit=
era_0240.jpg?width=1920&height=1080&fit=
era_0295.jpg?width=1920&height=1080&fit=
then I refitted the fuel pipes and brake pipe
era_0296.jpg?width=1920&height=1080&fit=
era_0297.jpg?width=1920&height=1080&fit=
era_0298.jpg?width=1920&height=1080&fit=
Edited by mk1leg, 12 May 2020 - 09:34 PM.
#117 clubman91
clubman91
  • Just Joined
  • 137 posts
Posted 18 May 2020 - 06:43 PM
This is looking great top job ?
#118 mk1leg
mk1leg
  • 9,343 posts
Posted 18 May 2020 - 09:08 PM
Hi..Peeps over the last few days I was bust cleaning down suspension parts ect etch priming them and painting them whilst subframes are being powder coated
era_0295(1).jpg?width=590&height=370&fit
era_0299.jpg?width=590&height=370&fit=bo
era_0300.jpg?width=590&height=370&fit=bo
era_0301.jpg?width=590&height=370&fit=bo
era_0302.jpg?width=590&height=370&fit=bo
era_0303.jpg?width=590&height=370&fit=bo
era_0304.jpg?width=590&height=370&fit=bo
era_0305.jpg?width=590&height=370&fit=bo
era_0306.jpg?width=590&height=370&fit=bo
era_0307.jpg?width=590&height=370&fit=bo
era_0308.jpg?width=590&height=370&fit=bo
era_0309.jpg?width=590&height=370&fit=bo
era_0310.jpg?width=590&height=370&fit=bo
era_0311.jpg?width=590&height=370&fit=bo
era_0312.jpg?width=590&height=370&fit=bo
era_0313.jpg?width=590&height=370&fit=bo
era_0314.jpg?width=590&height=370&fit=bo
era_0315.jpg?width=590&height=370&fit=bo
era_0316.jpg?width=590&height=370&fit=bo
era_0317.jpg?width=590&height=370&fit=bo
era_0318.jpg?width=590&height=370&fit=bo
era_0319.jpg?width=590&height=370&fit=bo
era_0320.jpg?width=590&height=370&fit=bo
era_0321.jpg?width=590&height=370&fit=bo
put shell back on axel stands
era_0322.jpg?width=590&height=370&fit=bo
era_0323.jpg?width=590&height=370&fit=bo
era_0324.jpg?width=590&height=370&fit=bo
era_0325.jpg?width=590&height=370&fit=bo
era_0326.jpg?width=590&height=370&fit=bo
era_0327.jpg?width=590&height=370&fit=bo
era_0328.jpg?width=590&height=370&fit=bo
era_0329.jpg?width=590&height=370&fit=bo
era_0330.jpg?width=590&height=370&fit=bo
era_0331.jpg?width=590&height=370&fit=bo
era_0332.jpg?width=590&height=370&fit=bo
removed bitumen ******* and rubbed down and etch primed cockpit and footwells
era_0333.jpg?width=590&height=370&fit=bo
era_0334.jpg?width=590&height=370&fit=bo
#119 johnR
johnR
  • 2,298 posts
Posted 19 May 2020 - 11:57 AM
1. great progress, coming together now helped by a bodyshell that was in great condition!
2. axle, not axel!:)
Edited by johnR, 19 May 2020 - 11:59 AM.
#120 mk1leg
mk1leg
  • 9,343 posts
Posted 20 May 2020 - 05:05 PM
have fitted front scuttle, front panel, boot floor repair, boot hinge repair, valance, I know its good compared to some projects but still a lot of work done
