Era Mini Turbo
227 replies to this topic
#91 mk1leg
mk1leg
  • 9,343 posts
Posted 30 March 2020 - 09:16 PM
day 7 of isolation another fine but windy day so test fitted new battery box and after a lot of feteling i got it to seat nicely
then I gage it a goos wire brushing (electric) and then a good sanding
 and the small holes that need attention
Day 8 od isolation and now Jersey is in lockdown day 1 I put a call out for a loan of a welder and low and behold 1 was dropped at my door this morning a big thanks to Keith lol i attempet to weld the front scuttle
not a bad effort as its been 12 years since I last used a welder
tomorrow I will fill the spot weld holes in windscreen edge
#92 mk1leg
mk1leg
  • 9,343 posts
Posted 01 April 2020 - 05:52 PM
Hi..peeps day 10 of isolation had a rest day yesterday due to welders Eye lol, I spent the day getting front panel to sit correctly,
then I offered up the bonnet but I stupidly put the hinges back in the wrong holes so off came everything and relocated the hinges in the correct place then refitted bonnet this needed several more attempts to adjust the new scuttle to back of bonnet to alignment correctly,
then offered up the front panel and got this to sit nicely to wings very pleased so all needs welding up next
#93 mk1leg
mk1leg
  • 9,343 posts
Posted 02 April 2020 - 05:09 PM
Hi..Peeps day 11 of isolation and day 4 of lockdown here in Jersey so another dry day started with removing the bonnet and front scuttle for ease of welding windscreen edge of scuttle
welded scuttle and rubbed down welds and applied etch primer to bare metal
welded on front panel and grind back spot welds and etch primed bare edged
fitted bonnet back and very happy with gaps
tomorrow I will clean up welds on wing to front panel joints and seam seal
#94 mk1leg
mk1leg
  • 9,343 posts
Posted 03 April 2020 - 04:27 PM
Hi..peeps final day of isolation and day 5 of lockdown today I've been fiddleing with the front panel and started with test fitting and adjusting New Stainless steel fog lamp brackets and drilling ready for riveting after paint
then I moved onto test fitting original body kit but front panel needed surgert to allow vent to pass
a bit more cutting
and it slides onto front panel
copied for the orher side and test fit the front kit
front kit needs a lot of work due to all the kerbs its hit in the past but I have a friend who a Fiberglass guru
I did purchase a new front kit from a UK firm but its a good copy so will not use it
#95 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 04 April 2020 - 04:19 AM
I never though it would actually have functional vents! Where does the air go?
#96 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 04 April 2020 - 09:37 AM
To the brakes
#97 mk1leg
mk1leg
  • 9,343 posts
Posted 04 April 2020 - 03:17 PM
Hi..Peeps I'm free of Isolation BUT day 6 of lockdown here in Jersey, todays efforts consist of drilling new Stainless steel body kit brackets to front panel and side skirt
the 2 front brackets kit to front panel
then applied some seam seal to wing reinforcements and wing seams and front panel
great progress this week
#98 mk1leg
mk1leg
  • 9,343 posts
Posted 05 April 2020 - 04:11 PM
day 7 of lockdown ans this afternoon I tackled a small hole in innerwing footwell,
last june I managed to get a section from a scrapper
and tidied this up and
then set about making it fit
tomorrow weather permitting I will weld it in place
#99 mk1leg
mk1leg
  • 9,343 posts
Posted 06 April 2020 - 06:26 PM
Hi..Peeps day 8 of lockdown and today I welded in the patch not a good job but pleased as it was a tricky mother...lol
then applied etch primer
next job was the passenger door
I removed the skin but not good need to order a filler piece
tomorrow the drivers door
#100 mk1leg
mk1leg
  • 9,343 posts
Posted 09 April 2020 - 05:10 PM
Hi..Peeps todays efforts I removes drivers door
did not look too bad but once I removed the door skin lol
so have ordered repair sections next I tackled the hard to get to welds and this was a tedious job and after several Dramen bits I'm happy
cleaned out wing gutter with electric wire brush and etch primed
then I gave the bonnet face a nother prime and then a coat of Black for protection
next applied filler to scuttle welds and rub down and primed
then applied seam seal to wing channel
then I scotehed the etch primer and applied a grey primer
then I attempted to see if the original bodykit would fit but this need cutting and twisting and re glassing after several accidents in the past and due to the lockdown I can not get glass and resin so this will have to wait....lol
Edited by mk1leg, 09 April 2020 - 05:12 PM.
#101 austinseven
austinseven
  • 76 posts
Posted 09 April 2020 - 08:07 PM
Try amazon for fibre glass filler I’ve ordered stuff of them and it’s arrived, maybe a bit later than usual but it’s arrived
#102 mk1leg
mk1leg
  • 9,343 posts
Posted 12 April 2020 - 02:10 PM
Hi.Peeps a little more done on the ERA took off the drivers door and at first look not too bad
I removed the skin and Opps
Moved on to the rear again as parts arrived from Minisport
note the mistake from Magnum panels
start to mark and cut out rear panel
test fit hinge repair
cit middle boot floor repair to size
next attach the valance and test fit all 3 parts and valance closing fitch needs adjustment will do this next time
#103 mk1leg
mk1leg
  • 9,343 posts
Posted 14 April 2020 - 04:16 PM
Good afternoon peeps today's effort try and cut boot repair panel and fiddle trying to get a good fit say a dozen times off and on
happy with fit will weld tomorrow
then I spot welded boot floor repair in place and applied copious amounts of seam sealer before I weld rear valance in place
also seal seales rear valance ends
also closing ends
tomorrow I will try and weld boot repair and rear valance
Edited by mk1leg, 14 April 2020 - 04:18 PM.
#104 mk1leg
mk1leg
  • 9,343 posts
Posted 17 April 2020 - 03:25 PM
Hi..Peeps a bit more done on the ERA first I welded in the boot repair panel
then I filled it
added in a boot light switch holser from a scrapped mini
welded in Valance
then I test fitted rear body kit and fitted Stainless steel brackets (temp)
Had these made from the old rusty ones I took off
then I fitted the boot back on to check it still fitted
#105 mini.30
mini.30
  • 288 posts
  • Local Club: I Ride Solo
Posted 18 April 2020 - 08:30 AM
Love this project
Amazing to think that one of these cars could fly under the radar for so long
Great work so far, good luck for the rest of Lockdown
Keep it up
Mark
