Era Mini Turbo
227 replies to this topic
#31 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 04 April 2018 - 07:59 AM
Very strange to see an ERA "naked", can't wait to see further progress. I have a real soft spot for the ERAs  :shades:
#32 mk1leg
mk1leg
  • 9,343 posts
Posted 08 April 2018 - 06:53 PM
they were hastily put together rear wheel arch rivets still  in rear panel front arche stiffeners only red oxide primed that's it and front panel ends are cut differently
#33 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 09 April 2018 - 08:02 AM
Seems to echo what I've seen before. You're doing it a service by taking it back to the shell and building it up again!
#34 mk1leg
mk1leg
  • 9,343 posts
Posted 13 April 2018 - 07:07 PM
Whilst the sun was out late afternoon I managed to get the ERA interior out and bagged to stop it getting damp or dirty
and as for garages with post lifts the damage they cause....need tosort this before its painted....lol
Edited by mk1leg, 13 April 2018 - 07:08 PM.
#35 hazpalmer14
hazpalmer14
  • 684 posts
  • Local Club: cumbria mini cruisers
Posted 13 April 2018 - 08:06 PM
Never seen one with the cloth seats, most ive seen had the leather. One i have seen most up close was E4 ERA
#36 mk1leg
mk1leg
  • 9,343 posts
Posted 15 April 2018 - 04:17 PM
managed to get the steering wheel and removed dashboard and the console ,door cards and rear bin and cards off
3 screws holding dash in place
4 screws holding console to tunnel
and today I had a go at refurbishing the bezels and backplate
sanded and primed and 2 coats satin black
and scrubbed the console clean and fitted new switches and wiped clock
#37 MrBounce
MrBounce
  • 2,644 posts
Posted 16 April 2018 - 03:58 PM
Superb work. Looking forward to further updates  :thumbsup:
#38 mk1leg
mk1leg
  • 9,343 posts
Posted 17 April 2018 - 10:07 PM
gauges and backplate refitted to dash
#39 mk1leg
mk1leg
  • 9,343 posts
Posted 29 April 2018 - 07:47 PM
I have managed to remove the engine and remove all parts in the engine bay
gave it a quick power wash ready to be sent to the UK for a rebuild
when I removed the heat shield there was no primer
Edited by mk1leg, 29 April 2018 - 07:52 PM.
#40 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 30 April 2018 - 12:28 PM
When you are lucky enough to get your hands on these type of original Mini variants then you would be excused for thinking that they were lovingly put together by a small team of craftsmen in long brown coats in an immaculate workshop with some soothing music being played in the background. From what you've found so far it looks like they've been hastily thrown together in a back street lockup on a Saturday morning after a hefty evening in da club!
#41 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 30 April 2018 - 05:05 PM
That's ERA for you!
#42 mk1leg
mk1leg
  • 9,343 posts
Posted 01 May 2018 - 09:21 PM
It wil be done Proper this time
#43 mk1leg
mk1leg
  • 9,343 posts
Posted 02 August 2018 - 08:53 PM
so been a while since I posted been working on other club members minis.....lol........
removed rear valance
just need to linnish back the spotwelds whilst awaiting new repair panels.........also any advice on pin holes in the wheel well can I just try and fill weld or ???
#44 Bat
Bat
  • 903 posts
Posted 02 August 2018 - 10:30 PM
Hi,
Have a go at fill welding, if it doesn't work out You've got the change the panel anyway.
Cheers  :proud:
#45 Daz1968
Daz1968
  • 2,058 posts
Posted 02 August 2018 - 10:56 PM
If I had pin holes in a panel, as long as I could get to both sides to clean properly I would drill a hole to enlarge the pinhole to remove corrosion to good metal, then put copper on the back and weld up the hole, depends how bad they are really, but I have had previous luck doing this method, if the pinhole needs a large hole to remove corrosion I would weld in a small patch, but all this depends on amount of holes vs cost and ease to change the panel.
Example of area I have done this is in the roof gutter after removing the drip rail, but this only had very small areas that needed work.
