Era Mini Turbo
227 replies to this topic
#211 mk1leg
mk1leg
  • 9,343 posts
Posted 14 May 2023 - 07:35 PM
radiator fan isn't fouling on anything is it ?
not sure I will investigate tomorrow
#212 slidehammer
slidehammer
  • 1,180 posts
  • Local Club: LSMOC
Posted 21 May 2023 - 04:04 PM
Did you make it to the L2B Run?
#213 mk1leg
mk1leg
  • 9,343 posts
Posted 25 May 2023 - 09:18 PM
yes but not with the ERA having electrical issues but engine runs so thats good lol
#214 slidehammer
slidehammer
  • 1,180 posts
  • Local Club: LSMOC
Posted 26 May 2023 - 12:47 PM
That is a shame, I did look out for your car and didn't see it. At least you went on the run. maybe next year!
#215 mk1leg
mk1leg
  • 9,343 posts
Posted 30 May 2023 - 05:57 PM
good evening peeps so I have finally yes finally finished My ERA turbo after a 6 year rebuild
ERA_rebuild_182.jpg?width=1920&height=10
ERA_rebuild_181.jpg?width=1920&height=10
[URL=https://hosting.photobucket.com/images/x259/mk1leg/ERA_rebuild_183.jpg?width=1920&height=1080&fit=bounds]ERA_rebuild_183.jpg?width=1920&height=10[/URL
just wheel caps to fit and its ready for test drive
a quick vid for those interested still a few nigly prob to sort out higher the rear sjustarides and stiffen up rear shocks but good to go to its first event on Saturday 3rd june here in Jersey many thanks to all who have left encouraging words
https://www.facebook...71790302079885/
#216 KTS
KTS
  • 2,399 posts
Posted 30 May 2023 - 09:33 PM
Congratulations - a sterling effort, and perfectly timed for the summer !
#217 colinf1
colinf1
  • 998 posts
Posted 30 May 2023 - 10:56 PM
Good stuff! Get out and about and enjoy it now!
#218 slidehammer
slidehammer
  • 1,180 posts
  • Local Club: LSMOC
Posted 31 May 2023 - 12:54 PM
It does look very smart and in my opinion the best colour they came in.
#219 wingnut
wingnut
  • 463 posts
Posted 31 May 2023 - 04:07 PM
Great job you've done there.Time to enjoy it
#220 mk1leg
mk1leg
  • 9,343 posts
Posted 06 June 2023 - 06:51 PM
Goog eveng peeps so I'd thought I had finished lol but took it for a test drive 3 days before a local show over here in Jersey and driving it along the lane where i Live and blurrrgh stalls restart it and 200mts same again so it did this all the way home so I found out that the oil pressure switch is different to that of the std mini  it uses an MG maestro turbo switch so I found 1 on Ebay and ordered it but said 1 week to deliver lol the following day  so I got in contact with a chap that owns the only other ERA here and asked If I could pinch his to try so the following day at 2pm I collected him and we went to his lockup and I took it off his ERA
ERA_rebuild_183_wQ1sn3yEdnSbTe8nh1ChzQ.j
and at 3pm I got home and low and behold a small parcel had arrived and it was the new Switch
ERA_rebuild_184.jpg?width=1920&height=10
so I fitted new switch and problem solved the night before Jersey's big show weekend
ERA_rebuild_189.jpg?width=1920&height=10
ERA_rebuild_185.jpg?width=1920&height=10
ERA_rebuild_187.jpg?width=1920&height=10
ERA_rebuild_188.jpg?width=1920&height=10
ERA_rebuild_186.jpg?width=1920&height=10
just 1 problem to solve but this can wait till winter Heater matris failed
#221 sonscar
sonscar
  • 2,944 posts
Posted 07 June 2023 - 07:26 AM
Looks very nice,well done.Steve..
#222 mk1leg
mk1leg
  • 9,343 posts
Posted 05 November 2023 - 04:37 PM
Good day Peeps a little Update on the running of My ERA, so after only 50 road miles back in june I had a head gasket failure, so I compression tested bores and the result was
ERA_headgasket_replace_1.jpg?width=1920&
so the stripdown started
ERA_headgasket_replace_2.jpg?width=1920&
ERA_headgasket_replace_3.jpg?width=1920&
ERA_headgasket_replace_4.jpg?width=1920&
ERA_headgasket_replace_5.jpg?width=1920&
ERA_headgasket_replace_6.jpg?width=1920&
the culpret lol
ERA_headgasket_replace_7.jpg?width=1920&
ERA_headgasket_replace_10.jpg?width=1920
ERA_headgasket_replace_9.jpg?width=1920&
check head for problems
ERA_headgasket_replace_11.jpg?width=1920
ERA_headgasket_replace_13.jpg?width=1920
found slipped valve stem oil seal
ERA_headgasket_replace_16.jpg?width=1920
ERA_headgasket_replace_12.jpg?width=1920
sent head to a workshop to get cleaned and new seals and reseat valves done
ERA_headgasket_replace_18.jpg?width=1920
ERA_headgasket_replace_20.jpg?width=1920
refit head and gubbings
new MED 3shim steel gasket fitted
Head_gasket.jpg?width=1920&height=1080&f
ERA_headgasket_replace_21.jpg?width=1920
then iit was off to France for a french mini weekend with Mini De La Baie in Normandy
MDLb23_7.jpg?width=1920&height=1080&fit=
enjoying the frence roads
MDLb23_13.jpg?width=1920&height=1080&fit
MDLb23_10.jpg?width=1920&height=1080&fit
MDLb23_11.jpg?width=1920&height=1080&fit
then a minor issue rubber oil pipe failed and dumped oil everywhere
MDLb23_12.jpg?width=1920&height=1080&fit
My friend Sebastian came with his trailer
MDLb23_4.jpg?width=1920&height=1080&fit=
and we loaded it on
MDLb23_5.jpg?width=1920&height=1080&fit=
and sorted the problem with the help of Sebastian and back on the road
MDLb23_2.jpg?width=1920&height=1080&fit=
MDLb23_8.jpg?width=1920&height=1080&fit=
My friend Snoopy enjoying the luxurary and comfort of ERA
MDLb23_9.jpg?width=1920&height=1080&fit=
stopping for refreshments
MDLb23_14.jpg?width=1920&height=1080&fit
then time to get ferry back to Jersey
MDLb23_1.jpg?width=1920&height=1080&fit=
and ERA is running fine and no more issues
Edited by mk1leg, 05 November 2023 - 04:43 PM.
#223 warning634
warning634
  • 489 posts
Posted 14 November 2024 - 11:20 AM
Hi all
I unfortunately has some very sad news Mark le gallais aka "mk1leg" sadly passed away on the 10th November 2024.
As many of you know Mark was an absolute mini nut through and through and I'm sure that he will be sorely missed by us all here on the mini forum.
Many thanks
Kevin
#224 Midas Mk1
Midas Mk1
  • 5,764 posts
  • Local Club: S.U.N.M.C
Posted 14 November 2024 - 12:21 PM
Very sad, RIP  :(
#225 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,793 posts
Posted 14 November 2024 - 10:59 PM
That's awful news.
I'm working through catching up on threads and was delighted to see this car finished
I didn't expect to read this though.
My thoughts are with his family and friends and I hope that he didn't suffer at all
