Era Mini Turbo
227 replies to this topic
#136 mk1leg
mk1leg
  • 9,343 posts
Posted 10 June 2021 - 07:58 PM
a bit more rubbing down drivers door reveal and hinge panel
prep_16.jpg?width=1920&height=1080&fit=b
prep_17.jpg?width=1920&height=1080&fit=b
and Apanel and drivers wing
prep_18.jpg?width=1920&height=1080&fit=b
prep_19.jpg?width=1920&height=1080&fit=b
#137 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 11 June 2021 - 07:54 AM
Looks like a really solid car!
#138 mk1leg
mk1leg
  • 9,343 posts
Posted 16 June 2021 - 06:58 PM
I have replaced the front scuttle, front panel, boot floor repair and new valance and boot hinge repair
#139 mk1leg
mk1leg
  • 9,343 posts
Posted 17 June 2021 - 07:16 PM
Good evening peeps 8hours spent over the last few evenings on scraping and sanding back the multiple repairs mostley to drivers side front spoiler also passenger side not as bad with 40grit by hand
prep_29.jpg?width=1920&height=1080&fit=b
prep_28.jpg?width=1920&height=1080&fit=b
prep_27.jpg?width=1920&height=1080&fit=b
prep_26.jpg?width=1920&height=1080&fit=b
prep_24.jpg?width=1920&height=1080&fit=b
prep_23.jpg?width=1920&height=1080&fit=b
#140 mk1leg
mk1leg
  • 9,343 posts
Posted 23 June 2021 - 09:43 PM
a nice warm evening rubbing dowm the rear arch and rear body kit
prep_36.jpg?width=1920&height=1080&fit=b
prep_34.jpg?width=1920&height=1080&fit=b
prep_33.jpg?width=1920&height=1080&fit=b
prep_32.jpg?width=1920&height=1080&fit=b
prep_31.jpg?width=1920&height=1080&fit=b
#141 bpirie1000
bpirie1000
  • Area Managers
  • 2,345 posts
  • Local Club: Amoc
Posted 25 June 2021 - 06:37 PM
These mini appear to be multiplying watch out... red one appeared as if from no where..
This happends to me too.. my wife has learnt to understand that... eventually...
I told here these rusty shape need to tick together.. safety in numbers and all that...
Great work...
#142 mk1leg
mk1leg
  • 9,343 posts
Posted 28 June 2021 - 06:46 PM
Great work...
no its been there since last June covered up this a terp needs new engine which I am Building
a bit more work on some parts over the weekend rubbed down boot lid and primed it
removed rust from bottom edge and etched primed
prep_37.jpg?width=1920&height=1080&fit=b
then primed
prep_38.jpg?width=1920&height=1080&fit=b
then applied seam seal anlng boot seam
prep_39.jpg?width=1920&height=1080&fit=b
then I rubbed down the front and etch primed and primed
prep_41.jpg?width=1920&height=1080&fit=b
prep_42.jpg?width=1920&height=1080&fit=b
prep_43.jpg?width=1920&height=1080&fit=b
prep_44.jpg?width=1920&height=1080&fit=b
#143 mk1leg
mk1leg
  • 9,343 posts
Posted 09 July 2021 - 08:40 PM
Good evening peeps so over the last few evenings trying to get gaps for grille and bonnet lip to align I'm happyish
prep_45.jpg?width=1920&height=1080&fit=b
also aligned aux water rad drilled fixing hole
prep_47.jpg?width=1920&height=1080&fit=b
prep_46.jpg?width=1920&height=1080&fit=b
also drilled holes for spot lamp wire's and grille fixing prior to painting
prep_48.jpg?width=1920&height=1080&fit=b
prep_49.jpg?width=1920&height=1080&fit=b
#144 longtimenomini
longtimenomini
  • 708 posts
Posted 10 July 2021 - 04:51 PM
Well done Looking great …. The good old days
I dumped the aux water rad and went to alloy rad. Repositioned the oil cooler and had a charge cooler front mounted rad .
Had no problems with overheating … it ran spot on in middle of gauge even with crazy boost ( I had over heating prior to ditching the aux rad and factory main rad)
#145 mk1leg
mk1leg
  • 9,343 posts
Posted 10 July 2021 - 06:46 PM
Good afternoon peeps some more done on shell today a quick wipe down with panel wipe of wings, windscreen pan, front panel and hinge panel, and a quick scotch cloth rubdown and rewipe and apply some etch in places and primer just to protect for now.
prep_51.jpg?width=1920&height=1080&fit=b
prep_52.jpg?width=1920&height=1080&fit=b
prep_53.jpg?width=1920&height=1080&fit=b
prep_54.jpg?width=1920&height=1080&fit=b
prep_55.jpg?width=1920&height=1080&fit=b
prep_56.jpg?width=1920&height=1080&fit=b
prep_57.jpg?width=1920&height=1080&fit=b
#146 mk1leg
mk1leg
  • 9,343 posts
Posted 11 July 2021 - 01:50 PM
Good afternoon peeps today I tackled the boot after it filling with 2" of water last October's storm when it took the tarp off the rear of the shell lol
prep_59.jpg?width=1920&height=1080&fit=b
prep_58.jpg?width=1920&height=1080&fit=b
so I rubbed it back and reprimed it
prep_61.jpg?width=1920&height=1080&fit=b
prep_62.jpg?width=1920&height=1080&fit=b
and applied base coat
prep_63.jpg?width=1920&height=1080&fit=b
prep_64.jpg?width=1920&height=1080&fit=b
prep_65.jpg?width=1920&height=1080&fit=b
and lacquered it
prep_66.jpg?width=1920&height=1080&fit=b
prep_67.jpg?width=1920&height=1080&fit=b
prep_68.jpg?width=1920&height=1080&fit=b
#147 mk1leg
mk1leg
  • 9,343 posts
Posted 12 July 2021 - 06:56 PM
Good evening peeps a few more hours today masked off and etch primed bare metal and primed 1st coat all this done with rattle cans just the roof to sand back and sort out door steps then I can use my Uncle's compressor and borrow a good spray gun to prime it properly lol
prep_69.jpg?width=1920&height=1080&fit=b
prep_71.jpg?width=1920&height=1080&fit=b
prep_72.jpg?width=1920&height=1080&fit=b
prep_73.jpg?width=1920&height=1080&fit=b
prep_74.jpg?width=1920&height=1080&fit=b
prep_75.jpg?width=1920&height=1080&fit=b
prep_76.jpg?width=1920&height=1080&fit=b
#148 mk1leg
mk1leg
  • 9,343 posts
Posted 17 July 2021 - 10:29 PM
good evening peeps done some more on the Shell over the last few days
cut out door step amd cleaned out rust and primed it
prep89.jpg?width=1920&height=1080&fit=bo
cut new panel to size
prep_86.jpg?width=1920&height=1080&fit=b
prep_87.jpg?width=1920&height=1080&fit=b
prep_88.jpg?width=1920&height=1080&fit=b
drilled plug weld holes and welded it in place
prep_79.jpg?width=1920&height=1080&fit=b
prep_81.jpg?width=1920&height=1080&fit=b
prep_83.jpg?width=1920&height=1080&fit=b
prep_84.jpg?width=1920&height=1080&fit=b
prep_85(1).jpg?width=1920&height=1080&fi
also made a start on sanding roof
prep_77.jpg?width=1920&height=1080&fit=b
prep_78.jpg?width=1920&height=1080&fit=b
#149 mk1leg
mk1leg
  • 9,343 posts
Posted 19 July 2021 - 08:57 PM
Good afternoon peeps had a day for the Queen today so I tackled the roof panel not an easy panel to rub down especially with a hole in it so etch primed gutter
prep_91.jpg?width=1920&height=1080&fit=b
prep_92.jpg?width=1920&height=1080&fit=b
prep_93.jpg?width=1920&height=1080&fit=b
and then primed
prep_94.jpg?width=1920&height=1080&fit=b
prep_95.jpg?width=1920&height=1080&fit=b
prep_96.jpg?width=1920&height=1080&fit=b
rubbed back and another prime
prep_97.jpg?width=1920&height=1080&fit=b
prep_98.jpg?width=1920&height=1080&fit=b
prep_99.jpg?width=1920&height=1080&fit=b
now I just need to borrow my Uncle's big compressor and borrow a spray gun and apply a few coats 2k primer
#150 mk1leg
mk1leg
  • 9,343 posts
Posted 24 July 2021 - 07:28 PM
A huge thank you to MCJs Club President for putting my door skins on now a step closer to having a full shell ready for base and top coat
prep_101.jpg?width=1920&height=1080&fit=
prep_104.jpg?width=1920&height=1080&fit=
prep_102.jpg?width=1920&height=1080&fit=
prep_103.jpg?width=1920&height=1080&fit=
then I sanded the door skins and applied etch primer just need to seam seal edges
prep_106.jpg?width=1920&height=1080&fit=
prep_107.jpg?width=1920&height=1080&fit=
prep_108.jpg?width=1920&height=1080&fit=
