Untitled by joa kwin, on Flickr
D16Z6 Automatic Swap
#121
Posted 22 June 2018 - 10:26 PM
#123
Posted 10 July 2018 - 09:48 PM
mini wheel 13x6 by joa kwin, on Flickr
mini rim 13x6 gloss black by joa kwin, on Flickr
new rims,
and I painted them gloss black to remove the purple line on the loop
#124
Posted 14 July 2018 - 06:33 PM
mini wheels 2 by joa kwin, on Flickr
mini wheels 3 by joa kwin, on Flickr
mini wheels by joa kwin, on Flickr
new 13x6's with 165/60/13 tires mounted and balanced this morning
#125
Posted 22 July 2018 - 03:44 AM
tow hook by joa kwin, on Flickr
37196142_10156464975111684_3232872882140872704_n by joa kwin, on Flickr
1 inch thick alloy for the tow hook
37272276_10156467741096684_5819130539424088064_n by joa kwin, on Flickr
the mock up subframe to build some new taller lower coilover mounts
my mock up subframe has hi-lo's and miniastic fast road coil springs
and upgraded arms
37152852_10156465411706684_776981256251375616_n by joa kwin, on Flickr
165/60/13 tyres mounted on some 13x6 rims, I lifted the suspension up to the point it started to lift the car off my jack stands
the gap between the tyre and the fender is 1.5 inches
#127
Posted 05 September 2018 - 05:23 PM
outside in the sun by joa kwin, on Flickr
mini outside
radiator mount 2 by joa kwin, on Flickr
radiator mounted
#128
Posted 15 September 2018 - 05:21 AM
#129
Posted 02 October 2018 - 02:53 AM
Jet Milling Machine by joa kwin, on Flickr
new to me toy I picked up
I started to build the new dash for the mini
switch pod 1 by joa kwin, on Flickr
switch pod 2 by joa kwin, on Flickr
del sol switch pod im building to hold the stock switches
#130
Posted 13 October 2018 - 07:50 AM
harley davidson mirrors i fitted to the door
mini mirror right side by joa kwin, on Flickr
I welded 1/4 inch nuts to the door skin, the base plate I made out of aluminum, (not pictured) but im using allen head bolts
mini on new wheels by joa kwin, on Flickr
mini outside with all the same size wheels and tires on it, those are the 165/60/13's
the side wall looks huge on them vs the old 175/50/13's
led spot lights by joa kwin, on Flickr
led spot lights I picked up a pair to use, plan to mount them behind the clubby grill, them suckers put out some huge light
#131
Posted 14 October 2018 - 07:56 PM
headlights by joa kwin, on Flickr
mini has lights now,
spent Saturday wiring up all the lights on the car, front and back
I have to order a rear fog light and a new set up for my plate lights, but the wiring is in place for those whenever I get them
and I ordered a new clear turn signal cover
Edited by joakwin, 14 October 2018 - 07:56 PM.
#132
Posted 27 October 2018 - 04:37 PM
boot hinges by joa kwin, on Flickr
boot hinges 2 by joa kwin, on Flickr
I started to build some internal boot hinges
#133
Posted 31 October 2018 - 05:08 PM
mk1 mmetro floor mat by joa kwin, on Flickr
mini is going to get a vehicle inspection for the motor swap at the local AZ MVD,
so I put the carpet on the floor in and my mk1 metro floor mats
#134
Posted 02 November 2018 - 11:55 PM
crank pulley by joa kwin, on Flickr
crank pulley gave up the ghost, so I had to call up the crank pulley from my itb d16 motor
mini rear by joa kwin, on Flickr
temp tag on the car,
#135
Posted 04 November 2018 - 04:01 AM
exhaust painted by joa kwin, on Flickr
new exhaust again, the old one was way to loud, so this time I rebuilt it but used smaller dia pipe in hopes to quiet it down
