D16Z6 Automatic Swap
181 replies to this topic
#91 richgilberto
richgilberto
  • 70 posts
  • Local Club: Long Island Mini Enthusiasts
Posted 27 January 2018 - 03:32 AM
38731594764_686317a07d.jpgsheet metal dash by joaquinn lopez, on Flickr
started to make my dash
39411297222_878a7b833b.jpg13x5 wheel by joaquinn lopez, on Flickr
the rims I'm looking at buying
Where did you find these? Ive been looking for 4x4 5-spoke wheels to put on my Honda conversion!
Edited by richgilberto, 27 January 2018 - 03:34 AM.
#92 joakwin
joakwin
  • 958 posts
Posted 27 January 2018 - 05:41 AM
they are trailer wheels but i found out they are made for 1/2inch wheel studs
and i only upgraded my wheel studs to 7/16's
i have a friend that did 12mm studs on his k20 mini
but i don't know if the hubs can handle being drilled out for 1/2 inch studs
#93 richgilberto
richgilberto
  • 70 posts
Posted 29 January 2018 - 02:25 AM
And this is why I need adult supervision - while bolt pattern was always obvious to me, it never occurred to me that I couldnt put wheels for bigger studs on there - I figured it would get filled out by using tapered nuts. ¯\_(ツ)_/¯
#94 joakwin
joakwin
  • 958 posts
Posted 03 February 2018 - 07:00 AM
40053787021_33b09c4cb7.jpgrear brakes 2 by joaquinn lopez, on Flickr
today i moved the location of the coilover
so that i could move the location of the caliper
caliper is just sitting on the rotor as of now, i have to make some new mock up brackets for it still
#95 joakwin
joakwin
  • 958 posts
Posted 08 February 2018 - 05:08 AM
40112696542_e09015bc71.jpgrear disc brake 3 by joaquinn lopez, on Flickr
finally happy with the mock up mounting bracket
Edited by joakwin, 08 February 2018 - 05:09 AM.
#96 joakwin
joakwin
  • 958 posts
Posted 14 February 2018 - 01:03 AM
38441342790_80f4f5fb5a.jpgreear brake caliper pad fitment by joaquinn lopez, on Flickr
this is how the pad fits onto the rotor with my bracket
39356243835_514fa15fc8.jpgrear brake 5 by joaquinn lopez, on Flickr
some t6160 aluminum plate that's going to get cut up in a few days
#97 joakwin
joakwin
  • 958 posts
Posted 16 February 2018 - 05:53 PM
39591721344_80fafc0bb7.jpgUntitled by joaquinn lopez, on Flickr
one bracket is cut out
plan to work on the 2nd bracket this upcoming weekend
Edited by joakwin, 16 February 2018 - 06:01 PM.
#98 joakwin
joakwin
  • 958 posts
Posted 18 February 2018 - 04:22 AM
25458366687_650dfcb574.jpgrear brake bracket by joaquinn lopez, on Flickr
my 2nd bracket in the works
i changed it up some and made the edges more round
in the next few days, i will clean up the lines and make them flow nicer
#99 joakwin
joakwin
  • 958 posts
Posted 19 February 2018 - 04:30 AM
2ndbracket
38541538970_ff731eaa08.jpgright rear bracket by joaquinn lopez, on Flickr
#100 joakwin
joakwin
  • 958 posts
Posted 19 February 2018 - 04:44 PM
40362115991_c6020e49a6.jpgmore brake brackets by joaquinn lopez, on Flickr
#101 joakwin
joakwin
  • 958 posts
Posted 23 February 2018 - 06:18 PM
39732336834_2a8f2ebae8.jpgrear control arm by joa kwin, on Flickr
i offset my rear control arms 3 inches outward
#102 joakwin
joakwin
  • 958 posts
Posted 27 February 2018 - 12:38 AM
40506131411_4d079dcaa4.jpgrear control arm by joa kwin, on Flickr
25635639117_7bb9b62c5a.jpgcoilover mount rear by joa kwin, on Flickr
the start of the new lower coilover mount.....again
25635682947_d8f37ac07d.jpgrear wheel mounted by joa kwin, on Flickr
13x6 wheel with +12et, wheel sticks out 6 inches
i have some wide body flares i want to run, and they are 6 inches wide
#103 joakwin
joakwin
  • 958 posts
Posted 28 February 2018 - 12:16 AM
25655544087_c5edbefdac.jpglower coilover mount by joa kwin, on Flickr
#104 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 28 February 2018 - 10:06 AM
That looks a lot of leverage on the shocker bolt and bracket. What strength bolt are you using?
#105 joakwin
joakwin
  • 958 posts
Posted 28 February 2018 - 02:31 PM
Grade 8 1/2inch bolt
Edited by joakwin, 28 February 2018 - 02:31 PM.
