video-1513036286 by joaquinn lopez, on Flickr
run video
Posted 12 December 2017 - 10:31 AM
Excellent. One big milestone passed
Posted 15 December 2017 - 12:06 AM
fuel tank had a few leaks
i fixed them and then the ring around the fuel level started to leak
and so i welded that and now the fuel level leaks out of the connector panel, so
thats just done for it
im thinking about just straight swapping to the honda tank altogether and forget this pos mini tank idea
im alittle upset right now
i wasted alot of time on that tank
i could just straight weld up the stock mini fuel level sender hole and try and find a aftermarket level that mounts to the top
Posted 15 December 2017 - 11:19 AM
On my G13B I used a standard mini tank and fitted the complete panel from the Suzuki tank into the top - used it for years but although it did not show any signs of leaking it did make the boot smell of gas if it was really full.
A SPI tank came up for peanuts - so I'm using that now with an upgraded pump - it has the hole in the top of the tank already.
Sender unit wise - I just swapped the Suzuki sender across to the the back of the mini fitting - you get a OEM seal and the loom specific sender that way.
Edited by DomCr250, 15 December 2017 - 11:21 AM.
Posted 15 December 2017 - 10:38 PM
yeha I had a mpi tank with a Honda fuel pump and the Honda fuel level sender as well
just too many small holes in this tank
so I'm going to run the stock Honda tank for now
and re-visit the mpi tank in a few months, give me time to stop be upset with it and have the car running and the Honda tank will give me time
to work out all the pin holes in the mpi tank
I plan to have the car running on the Honda tank this weekend
Posted 17 December 2017 - 07:10 PM
i got the car running again, now with the honda tank, fits into my boot with the mod floor i did a few years back
its raining today here
and i wanted to start pulling the exhaust off the del slow but im not working in the rain
it can wait a few days
i hope it clears up tomorrow and i'll knock it out after work
i plan to install the cat, and then the cherry bomb muffler, 90deg bend and have the pipe come out the side in front of the right rear wheel
thats plan right now so i'll see how this works out when it comes time to measuring everything out
Posted 21 December 2017 - 05:39 AM
found a non-vented fuel cap with a pair of keys in it
got the exhaust off of the del slow chassis today and cut it up
and had to go buy some adapters for the stock pipe to cherry bomb muffler
tomorrow im going to bolt it together and start measuring some stuff
hope to have the exhaust built before the end of the year
Posted 28 December 2017 - 12:41 AM
built part of the exhaust today
moved the cat from its stock location to 12inches rear ward, and used 2inch pipe off of the y-pipe to cat
and then 3inches of 1-7/8's pipe and adapted it up to 2.25, and used a 2.5 inch inlet/out cherry bomb
and thats as far as i got on the exhaust today
i plan on making the exhaust come out at the right rear behind the back wheel
Posted 03 January 2018 - 01:29 AM
sheet metal dash by joaquinn lopez, on Flickr
started to make my dash
13x5 wheel by joaquinn lopez, on Flickr
the rims I'm looking at buying
Posted 03 January 2018 - 08:02 AM
If you're moving the cat so far away from the engine as you still confident it will get hot enough to work?built part of the exhaust today
Posted 03 January 2018 - 10:29 PM
I hope so, if not then I will just straight remove it
Posted 10 January 2018 - 12:44 AM
Posted 13 January 2018 - 07:32 PM
Posted 23 January 2018 - 11:50 PM
coilover bar by joaquinn lopez, on Flickr
coilover tower bar that i made that connects the two sides together
Posted 26 January 2018 - 09:53 PM
rear disc brake by joaquinn lopez, on Flickr
i started to work on installing disc brakes onto the rear of my car
before i had mini sport brake assy, and some mini fin drums
this rotor is a Honda 9.4 inch solid and uses a single piston caliper and has the park brake set up for a cable pull
