D16Z6 Automatic Swap
181 replies to this topic
#61 joakwin
joakwin
  • 958 posts
Posted 12 November 2017 - 12:14 AM
38314289222_d7530a66c5.jpgsteering set up by joaquinn lopez, on Flickr
Honda steering column is done
#62 joakwin
joakwin
  • 958 posts
Posted 15 November 2017 - 05:47 AM
26654259589_2d54c223ef.jpg23549640_10155802732061684_1467161470_n by joaquinn lopez, on Flickr
#63 joakwin
joakwin
  • 958 posts
Posted 20 November 2017 - 11:15 PM
the starter and the alternator is wired up, the under hood fuse box is wired up, the cruise control box is mounted and wired and throttle cable is hooked up
i got a cannon plug for the head light wiring harness stuff
and im getting ready to make the lower radiator mounts
and i ordered a longer throttle cable, stock cable was good for lhd, no good for rhd
#64 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 21 November 2017 - 09:52 AM
If the new stock cable is still not right, you can get an universal one for a motorbike and cut it down, you can then solder on the correct ends supplied with the kit.
Nice work by the way.
#65 joakwin
joakwin
  • 958 posts
Posted 23 November 2017 - 04:02 AM
thanks for the info
i'll look into it, the longer cable should be in Friday, so i'll see if I wasted my money or not
#66 joakwin
joakwin
  • 958 posts
Posted 23 November 2017 - 04:12 AM
38535352746_3f725d6064.jpgrad mount by joaquinn lopez, on Flickr
started working on the rad mounts tonight
#67 joakwin
joakwin
  • 958 posts
Posted 25 November 2017 - 04:45 AM
38596365532_7c0fb2cd87.jpgthrottle cable by joaquinn lopez, on Flickr
worked on wiring today and I got my throttle cable in the mail
the front clip wiring is done
I used 18 pins out of a 20 pin cannon plug
my throttle cable is from a gen 1 Honda odyssey van(95-98) f22 motor
I guess the cable bracket is in different spots on the intake manifold
because I need to ext mine out about 2.5-3 inches....no biggie
not bad overall, I paid 20 USD for the cable from rockauto
and from what I have seen online, they want 50 USD for rhd throttle cables
the stock lhd cable was 38 inches and way to short to be used in a rhd set up
and this odyssey cable is 53 inches, just right length for what I need
probably take me more time to paint the bracket then cut and weld it up
and now I don't have to use a custom cable
#68 joakwin
joakwin
  • 958 posts
Posted 26 November 2017 - 05:47 AM
37929741194_04878d46bb.jpgthrottle bracket by joaquinn lopez, on Flickr
new throttle cable bracket made out of some 3/16 plate I had laying around
throttle from the pedal works now
one step closer
Edited by joakwin, 26 November 2017 - 05:47 AM.
#69 joakwin
joakwin
  • 958 posts
Posted 02 December 2017 - 12:26 AM
24900898698_c109b12528.jpgtrans cooler by joaquinn lopez, on Flickr
free automatic trans cooler my brother gave me
#70 joakwin
joakwin
  • 958 posts
Posted 02 December 2017 - 10:32 PM
38076819314_a3782ffe3b.jpgfuel tank by joaquinn lopez, on Flickr
#71 joakwin
joakwin
  • 958 posts
Posted 05 December 2017 - 01:33 AM
Honda fuel level sender with mini seal and lock ring
and still have room to drop the pump inside the tank
#72 joakwin
joakwin
  • 958 posts
Posted 07 December 2017 - 11:04 PM
drivetrain now has coolant, trans oil, engine oil in it
I have to wire up the rear plate lights and fog light and figure out what switch I'm going to use for the fog light
02 sensor install, plus make the rear half of the exhaust
brake lines all around, install calipers
fuel lines, install fuel tank, ext fuel pump pick up tube, ext fuel pump and fuel level wiring
finish building the positive battery cable, build battery mount, install battery ground cable
the list is getting short, to having the car running
but I still need to do the interior work, but I want to hear it run before anything inside happens
#73 joakwin
joakwin
  • 958 posts
Posted 09 December 2017 - 10:35 PM
i had to mod one corner of my fuel tank, but it fits good now
i have three lines ran from the tank to the firewall area of the car now
i plan on running the stock purge canister for emission stuff
and then the send and return lines for fuel
i still need to wire up the fuel pump and fuel level gauage, i plan to do this after lunch
#74 joakwin
joakwin
  • 958 posts
Posted 10 December 2017 - 05:24 PM
38247186244_b54704e410.jpgpurge canister by joaquinn lopez, on Flickr
38077076355_4f53566cd2.jpgfuel tank in boot by joaquinn lopez, on Flickr
fuel lines are installed and I even ran a line from the tank to the purge canister and lines from the intake manifold to the canister
I want the drivetrain to run like it did when it was in the del slow chassis
so I'm installing everything from the donor car on over
I still need to make a battery mount but I had it hooked up and tried to turn it over but the battery was dead,
so I slow charged it over night
#75 joakwin
joakwin
  • 958 posts
Posted 11 December 2017 - 11:46 PM
the automatic drivetrain started today,
i have a fuel leak in my tank, so i have to drain the fuel and purge it and re-weld the leak
but the motor has a vaccum leak
and it was idling a bit high but after letting it run for a few mins, the idle started to come down and go to a normal idle speed
so im not sure if its kind of doing a relearn or whatever because it hasn't ran in a long time and the computer hasn't had power in a long time
trying to upload a video right now
so when the internet stops being slow i guess it will work
