D16Z6 Automatic Swap
181 replies to this topic
#31 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 08:16 PM
37014094260_5c8c2c7707_z.jpg1525332_10152164000696684_1001570218_n by joaquinn lopez, on Flickr
top view of 9.5 inch rotor with wilwood 4 piston calipers and steel braided brake lines
#32 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 08:19 PM
37397204225_c7006bc964_z.jpgmini apart by joaquinn lopez, on Flickr
itb motor and trans on a moving cart, pulled the motor to clean up the firewall a bit and cut a firewall box for stock d16 automatic set up, I made the box extra large
35860987940_e621e07cd1_z.jpgFailed front brakes by joaquinn lopez, on Flickr
I crashed my 03 R53 when the master cylinder when out and I came to a dead end road and had to put it in the water gutter
37412254065_493b9f8ceb_z.jpgmini firewall by joaquinn lopez, on Flickr
my firewall hole I cut
Edited by joakwin, 23 September 2017 - 08:33 PM.
#33 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 08:21 PM
37223508466_751baa5b95_z.jpg21415046_10155614683176684_2480772798108105520_o by joaquinn lopez, on Flickr
half way done with my firewall box
37223508386_007ee9ec0c_z.jpg21432924_10155625595016684_6713275661532891710_n by joaquinn lopez, on Flickr
firewall box painted and bed lined
Edited by joakwin, 23 September 2017 - 08:22 PM.
#34 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 08:31 PM
i started to strip the paint off the shell because i want to repaint it
the old paint has been on the car since Sept 2013
i figure with changing the drivetrain out to automatic, i should repaint it as well
I'm not sure if I'm going to keep it the same almond white color or paint it o.d. green
but I have a ton of time to figure it out
I can only work on this car when my hips don't hurt to much, which is all the time
37014558060_a5d5e6405d_z.jpg13336116_10154198575531684_6465963889239848846_n by joaquinn lopez, on Flickr
drove out to San Diego for this show, it was 425 miles each way
37223658426_5813bdbb34_z.jpg385066_10151189778656684_1699603312_n by joaquinn lopez, on Flickr
37223658626_e743902a00_z.jpg189220_10151189779036684_713274740_n by joaquinn lopez, on Flickr
smooth out the rear and shaved the bumper and its mount
37223658326_173ec26d76_z.jpg386805_10151113062031684_1703586441_n by joaquinn lopez, on Flickr
this is the green that I'm thinking of changing my car to
#35 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 08:46 PM
36560742184_32e5499ed7_z.jpg16807456_10154977932316684_4195011696546693898_n by joaquinn lopez, on Flickr
part of the amp rack for the garage system, over 5k watts in this picture
36560740204_f7b61fbf32_z.jpg13924958_10154350715156684_1925464140485363609_n by joaquinn lopez, on Flickr
rdx 410cc injectors with obd1 adapters
36560740414_cfdd0f212f_z.jpg10628796_10152901818581684_3057559597750512358_o by joaquinn lopez, on Flickr
my old red lodge house with my car on jackstands from June 2009
right after I got my mini
36560740064_5e0e496652_z.jpg16142370_10154901949806684_7580130941496280635_n by joaquinn lopez, on Flickr
R53 mini and lhd mini at my parents house in San Diego
36560739594_5b7639c67d_z.jpg18664469_10155285586836684_5393453491912290085_n by joaquinn lopez, on Flickr
R53 and my classic in my drive way in Tucson
36560739964_76ec63b908_z.jpg16425920_10154912784986684_4783093770290858846_n by joaquinn lopez, on Flickr
I was hand building a metal intercooler thingy for the R53
36560739774_a663c32522_z.jpg17264329_10155034327916684_7008501905239785353_n by joaquinn lopez, on Flickr
getting close to being done
this part never was installed on my R53 because I  totaled the car before I was done with the small project
#36 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 08:47 PM
36560739644_52fa7c0d30_z.jpg18010498_10155165042266684_7675947803912179087_n by joaquinn lopez, on Flickr
the last mini show I went to in the UK, I have this poster in my garage
#37 joakwin
joakwin
  • 958 posts
Posted 24 September 2017 - 04:58 PM
37288791241_2dfe4fe398_z.jpg21762083_10155664378896684_8066477651279340168_n by joaquinn lopez, on Flickr
drive train almost ready to come out
#38 joakwin
joakwin
  • 958 posts
Posted 30 September 2017 - 11:10 PM
37418140881_8e9c5d75a7_z.jpgmotor out by joaquinn lopez, on Flickr
drivetrain out from the del slow
I changed the left side mount to the eg style over the 3 bolt style it had,
my poly billet mounts are for eg style
I installed a gates timing belt kit
and a oem Honda water pump into the motor when it was out
#39 joakwin
joakwin
  • 958 posts
Posted 30 September 2017 - 11:13 PM
23565947388_8566323024_z.jpgright side subframe by joaquinn lopez, on Flickr
I had to start over with my subframe because the automatic gearbox is so much bigger then the manual
I had to move the engine out 2 inches so that the gearbox would clear the steering rack and the upper control arm mount on the suspension tower
and I didn't want to build custom upper control arms
i'll be fine because I have a clubby front clip
I ended up using 1.25 seamless tube to build my subframe
I still need to brace it up
#40 joakwin
joakwin
  • 958 posts
Posted 01 October 2017 - 05:53 PM
37403578592_3291a0eb78_z.jpgmini engine mount by joaquinn lopez, on Flickr
my rear engine mount bracket with poly billet mount
I made this last night
#41 joakwin
joakwin
  • 958 posts
Posted 02 October 2017 - 12:28 AM
rear motor mount that I worked on last night
37393919666_e9b984b21c_z.jpgmotor rear mount by joaquinn lopez, on Flickr
#42 joakwin
joakwin
  • 958 posts
Posted 02 October 2017 - 12:32 AM
37410338992_b5f0232202_z.jpgautomatic motor by joaquinn lopez, on Flickr
bent some 1.25 inch dom tube for the left side of the subframe
I just need to make the center crossover tube
but I ran out of tube today so I need to go and buy somemore tomorrow
metal place is closed on sundays
and I plan to use 3 inch triangles 3/16 thick to brace up everything on the subframe
I should have the subframe done this week and pull the engine from it and pull the subframe from the car
to do finally welding and paint it black
I still need to make the tie rod mounts but that wont take to much time
but I need to get the car on its wheels before I can make those
#43 joakwin
joakwin
  • 958 posts
Posted 03 October 2017 - 01:18 AM
36754339634_fa17fd82f4_z.jpgmini frame by joaquinn lopez, on Flickr
#44 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 03 October 2017 - 02:59 AM
Thanks for posting this, you're the first one I've seen put a Honda D series in a Mini with an Auto trans. I was wondering whether it could be made to fit as I drive an auto also 2009 Clubman S - due to age and bad knees in my case. My current classic is a stick, but I'm planning a project with an Ecoboost 3 cyl, with an auto trans.
I was at the MMW in Sandy Eggo too, wonder if we talked there?
#45 cooperS
cooperS
  • 116 posts
  • Local Club: MOC Santiago, Chile
Posted 03 October 2017 - 01:41 PM
hi, can you please give me the callipers/disc and drive flange part numbers??? are those callipers direct firment???
