D16Z6 Automatic Swap
181 replies to this topic
#181 joakwin
joakwin
  • 958 posts
Posted 21 February 2024 - 07:03 PM
was finally able to reset my pass word on the forum here, it was being a pain
i took the car apart again, its getting cut up somemore
no more honda powered, its going to chevy ls powered, rwd
i swapped the shell onto a shorten cj7 jeep frame, 2 inches longer then a cj5 wheel base
i rebuilt a 2004 lm7 5.3 engine, and a 4l60e trans, and a right side drop vss np241c, wiring harness is done, unlocked the ecm for it, i have the mock up block and trans and t-case sitting in the frame right now, i have to do sheet metal work to the shell, but i have the shell outside right now, dont have room inside the garage at this point,
so sheet metal work will start again when the weather gets better, and stops snowing
inside the garage, i have a lhd 75 mini, rebuilding the shell over the winter and doing a 1991 g10 3 banger swap into it, trying to make it light weight, and doing 4 wheel disc brakes on it and 10 inch wheels, the g10 has been rebuilt, and axles are done, drivetrain sitting in the front subframe, and im in the process of building my own rear suspension set up/ disc brake kit
i will post pictures later, dont have alot of signal on my phone at work to post pictures right now
#182 joakwin
joakwin
  • 958 posts
Posted 25 February 2024 - 06:39 PM
53551632746_7823c566fa_h.jpgUntitled by joa kwin, on Flickr
The new look of the mini
