D16Z6 Automatic Swap
181 replies to this topic
#166 joakwin
joakwin
  • 958 posts
Posted 15 August 2019 - 10:16 PM
68705398-2943548105715461-58004437594894
#167 joakwin
joakwin
  • 958 posts
Posted 16 August 2019 - 04:37 PM
68716107-2392374634163195-16507107009993
test fit in the seat and car
#168 joakwin
joakwin
  • 958 posts
Posted 20 August 2019 - 03:09 PM
69355480-767251010374298-485470424022174
working on adjusting the led head lights and led aux lights
68705017-349495339293630-145027966122013
billet rear hub bearing caps
and new front black seat belts came in
#169 hotroder69
hotroder69
  • 75 posts
Posted 28 April 2020 - 09:46 PM
Coming along nicely, Like the 37' too. I just finished  35' Ford pickup for a customer. I'm building a Mini pickup for myself.
Cheers, from Texas.
#170 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 28 April 2020 - 10:48 PM
Hope he's OK, haven't heard from him in 8 months....
Joakwin, what are the seats from? They look similar to the Subaru seats I put in mine, except mine have removable headrests.
#171 TooFPaste39
TooFPaste39
  • 83 posts
Posted 17 May 2020 - 02:25 AM
Amazing build.
I was stationed in RAF Mildenhall and that's where I found the love for these classic Mini's.  Cant wait to see the rest of your progress.
#172 joakwin
joakwin
  • 958 posts
Posted 22 February 2021 - 09:43 PM
The seats are from eBay
I haven’t been logged into here for a long time, I’m
In the process of moving out of state right now
But I’m thinking of removing the automatic Honda and doing a geo metro g10....for a light weight set up, see if I can get the car to under 1200 lbs, well maybe 1300 lbs
#173 riktanius
riktanius
  • 233 posts
Posted 28 February 2021 - 05:33 PM
25011265347_1f6fee8f96.jpgrear disc brake by joaquinn lopez, on Flickr
i started to work on installing disc brakes onto the rear of my car
before i had mini sport brake assy, and some mini fin drums
this rotor is a Honda 9.4 inch solid and uses a single piston caliper and has the park brake set up for a cable pull
I need to understand all your brake upgrades. You make it look like it is all just drop in, but I haventt seen anythign so easy on a mini before.
#174 joakwin
joakwin
  • 958 posts
Posted 17 March 2021 - 01:36 PM
I made a bracket to bolt the Honda caliper onto the mini 3 bolt arm, it’s made out of 1/2 inch aluminum, I think I used 5160, but I can’t remember, one section of the bracket, were it mounts to the minis rear arm, I had to taper it, machined it down to 3/8’s thick, I used counter stunk bolt heads so the bracket would clear the hub, I have billet hubs from dsn classic as well, I made my mock up bracket out of 3/8’s wood, much easier to cut wood into the shape then metal or aluminum, I think I made around 10 wooden brackets before I finally got it right,
I am also using Honda rear solid rotors, I changed the stud size on my mini from 3/8’s to 7/16’s, I’m using aftermarket studs, some super long ones, and when I changed the stud size, I also drilled the Honda rotor for the 4x101.6mm pattern (4x4), vs Honda that comes with a 4x100 bolt pattern
I got the studs from summit racing, think they are for a Chevy truck from the 60’s
The Honda del sol rear rotors are a solid 9.4 inch rotor and up
Front I have some Hyundai Accent rotors, I think they are from a 98, they are vented 9.5 inch rotors, they were $20 each from autozone
And I have some aluminum adapters that connect the rotor to the minis hub flange
And I used some wilwood 4 piston calipers, the ones with the 3.5
Mount that come straight out, they bolt directly to the minis spindle
And then I also put the rest of the Honda del sol brake system into my mini
I had a wilwood pedal box before but didn’t like the master cylinders reseviors, they kept on leaking brake fluid
So I changed that triple master cylinder pedal box out for a oem Honda set up
I have the pedal box/booster/mc and prop valve from the Honda
The pedal box and booster are mounted inside the car
And the master is mounted to the firewall
And the prop valve is mounted lower on the firewall
I used steel braided lines (-4) off the master to the prop valve
And off the prop valve to front calipers as well, and a short section of steel braided line to hard line for the dual rear lines for the rear brakes
#175 joakwin
joakwin
  • 958 posts
Posted 17 March 2021 - 01:48 PM
If I were to do the rear disc set up again, I would use vw golf calipers, they aren’t as wide as the 95 Honda del slow calipers, the Honda calipers worked for me because i made my arms offset 3.5 inches outward for my body kit I put on the car
Edited by joakwin, 17 March 2021 - 01:48 PM.
#176 joakwin
joakwin
  • 958 posts
Posted 17 March 2021 - 03:31 PM
https://flic.kr/p/247C4bf
Here’s the caliper mounted with the wood bracket without the rotor
#177 joakwin
joakwin
  • 958 posts
Posted 17 March 2021 - 03:34 PM
https://flic.kr/p/24ktZyo
Here’s the part of the bracket that I had to thin down to 3/8’a thick
#178 Maccmike8
Maccmike8
  • 1,101 posts
Posted 17 March 2021 - 04:26 PM
Use IMGBB for photo uploads pal. We'll be able to see them on your thread then.
#179 joakwin
joakwin
  • 958 posts
Posted 17 March 2021 - 04:38 PM
Yeah, I’m on my phone right now, it’s not giving me the option of that from the app, or I don’t know how to....sorry
#180 riktanius
riktanius
  • 233 posts
Posted 18 March 2021 - 11:43 AM
Thank you for the detailed breakdown. I was really hoping that it was more... easy. LOL.
