D16Z6 Automatic Swap
181 replies to this topic
#1 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:04 AM
my car started out as a B reg 85 mini mayfair, it was a 998 auto
and then it became a 1275 automatic from a 83 metro
and then i swapped in a d16z6 itb manual trans and drove it around suffolk alittle bit
and then i moved back to the states
here is the early years of my rebuild
36999289680_670f65f120_z.jpgmini uk by joaquinn lopez, on Flickr
37397203905_1972031247_z.jpgmini uk 2 by joaquinn lopez, on Flickr
#2 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:10 AM
37397206305_3a32c7a335_z.jpgmini primer by joaquinn lopez, on Flickr
I replaced the floors, the rocker panels, the inner fenders, the boot floor, the lower half of the side body panel in front of the rear wheels, the doors, the corners of the windshield and closer panel for it,
the rear roll pan and the closer for that panel
and de-seamed the car as well
shaved the bumpers
and fixed the dents in the roof
and cut out the rear seat bins on each side
and replaced the inner and outer metal that the front doors hang off of
the side panel had a rust hole under the pop out windows
and the side panel in front of the rear wheels had cardboard and p38 over that
when I took the rear subframe off, the front bolts broke, so I grinded them off and welded in new nuts on the inside of the subframe front mount panel
the car has a cds tube roll cage
#3 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:15 AM
37207821746_6f995de88f_z.jpg204364_10150165067981684_2821633_o by joaquinn lopez, on Flickr
roll cage plates
36545054734_d32b77dca1_z.jpgrear suspension by joaquinn lopez, on Flickr
rear subframe with alloy hubs and mini fins
#4 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:19 AM
37397204095_8ab74c31fc_z.jpgmini paint by joaquinn lopez, on Flickr
I painted the shell back in Sept of 2013
37254912011_9988929a09_z.jpgmini tbi motor by joaquinn lopez, on Flickr
fitting the subframe with motor  for the 1st time
#5 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:20 AM
37254903681_7b4de903cd_z.jpgbrakes by joaquinn lopez, on Flickr
brakes and pedal box
37254903651_5610b98c09_z.jpgcluster by joaquinn lopez, on Flickr
cluster
#6 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:21 AM
37207821566_10de7a31e4_z.jpg1479429_10152074030031684_1183886774_n by joaquinn lopez, on Flickr
fitting doors to the body again after paint
#7 joakwin
joakwin
  • 958 posts
37225555612_61170cf547_z.jpgmini grill by joaquinn lopez, on Flickr
mini grill
#8 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:22 AM
36585072173_faf0e5c5e8_z.jpgitb mini by joaquinn lopez, on Flickr
mini in the states almost back together
#9 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:23 AM
35425385163_4018419090_z.jpgthe twins by joaquinn lopez, on Flickr
re-doing the group 6 arches and repainting the front clip
37225551872_5668ff517f_z.jpgmini by joaquinn lopez, on Flickr
#10 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 02:26 AM
36231197965_711d7e7e20_z.jpgwide body kit by joaquinn lopez, on Flickr
at the time I was thinking of making the mini a wide body mini
37397204225_c7006bc964_z.jpgmini apart by joaquinn lopez, on Flickr
pulled motor a few weeks ago, going to swap the built manual lsd d16z6 itb motor for a stock d16z6 automatic
I hurt my hips and can no longer drive a manual car, I have had double hip surgery and can only drive automatic cars now
Edited by joakwin, 23 September 2017 - 02:27 AM.
#11 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 07:32 PM
36065515072_0b1565a2e4_z.jpgUntitled by joaquinn lopez, on Flickr
the donor car, 1995 Honda del sol si, I got it at a dealer auction place for $275USD, $180 USD auction fee, $16USD sales tax
35425171163_51d7415f39_z.jpgd16z6 auto by joaquinn lopez, on Flickr
under the bonnet
36166002681_fceed1fea4_z.jpgBad iat sensor by joaquinn lopez, on Flickr
it had one bad sensor and then it passed the smog test
I drove the donor car around for almost 6 weeks
I replaced the 02 sensor and this iat sensor, and the fan switch sensor, and the thermostat and I had to replace the in-car fuse box
I wanted to drive the car around to make sure it had no bugs in it
#12 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 07:33 PM
35465925164_2fe5059fb6_z.jpgUntitled by joaquinn lopez, on Flickr
here is the paperwork for the smog test
the 1st fail was because the iat sensor was bad
and the light for the check engine light didn't work, so i had to figure that out and i found the iat was bad
Edited by joakwin, 23 September 2017 - 07:34 PM.
#13 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 07:39 PM
37234268291_7b60bf2e7e_z.jpgvalve cover off by joaquinn lopez, on Flickr
I got a new gates timing belt kit and a oem water pump for the donor car because the cluster says it has 202k miles on it
but when I removed the valve cover, no way this motor has 202k miles on it
and then I also noticed that it has a gates timing belt and aftermarket water pump, and it has a blue head gasket, which I think is a felpro head gasket
I think this motor was rebuilt not to long ago
I need to buy a Carfax report on this car, but I have a buddy that said he can look it up for free
so I'm waiting for him to look it up for me, but he's taking his sweet time
so I'm thinking since I have a new timing belt kit for this donor motor, for peace of mind, change it anyways
because I have no vehicle maintenance history on this car
#14 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 07:43 PM
37269540021_a185f17682_z.jpg1275 by joaquinn lopez, on Flickr
here is a picture of my old 1275 automatic metro engine
#15 joakwin
joakwin
  • 958 posts
Posted 23 September 2017 - 07:47 PM
37412095475_edc83ac5ba_z.jpg253241_10150203810671684_2663240_n by joaquinn lopez, on Flickr
when I started to de-seam the shell back in 2009
37412095615_40b56e26a9_z.jpg247856_10150203810556684_6149595_n by joaquinn lopez, on Flickr
37412095935_c9a941bf93_z.jpg41219_427250771683_459533_n by joaquinn lopez, on Flickr
37412096005_953f7856d4_z.jpg38114_415154306683_3240404_n by joaquinn lopez, on Flickr
grp dash that I ended up changing my mind on using
