Suspension Recommendations
13 replies to this topic
#1 R32Egor
R32Egor
  • 299 posts
Posted 13 September 2017 - 12:59 PM
Suspension recommendations - Always a tricky and emotional discussion!!!!
I am restoring my 1997 MPI sportspack. I was thinking about using a coil replacement kit but after reading all of the comments here I think i will stick with rubber!
What I would like to know is a better than original suspension setup that I could do with the donuts.
This can include -
13 x 7 wheels instead of the standard
camber and caster changes but not extreme
I would like the ride height to be lower than standard (changeable)
Going to using kad lightened swing arms and will be looking to save suspension weight elsewhere as well.
The goal is for a 90HP fast road mini with maybe (much) later conversion to supercharged (110hp)
Obviously going to be uprating the brakes and while the car is under restoration then should look at everything
As there as so many components out there it would be good to get some input. :D  :D
#2 nicklouse
  • 18,556 posts
Posted 13 September 2017 - 01:12 PM
thoughts.
good.
bad wheel size for ride quality grip and speed.
suspension set up as needed with adjustable parts.
HiLos to set ride height
KAD swing arms money that is not needed to be spent and would do better going elsewhere. like wheel size.
brakes SuperFins rear and alloy 4 pots and solid discs. pad material personal choice.
#3 Mini Manannán
Mini Manannán
  • 2,856 posts
  • Local Club: man Estate
Posted 13 September 2017 - 01:49 PM
Stick with rubber cones.  I inherited some Minitastic coils on my mini.  I've just changed it all to hilos and rubber cones and the difference is like night and day!  The ride is much plusher and forgiving and all the rattles and squeaks have disappeared :-)
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 13 September 2017 - 03:47 PM
I run 13's on mine because I like the look of them but they're a real handfull when I'm pressing on. They follow every whiteline in the road and they tramline and because of the reduced sidewall they lose out on a lot in terms of comfort, but hey, I'm a slave to fashion :D . Unless you want 13's because of the look I'd fit 12's, they're a great compromise between looks and handling.
#5 R32Egor
R32Egor
  • 299 posts
Posted 13 September 2017 - 04:10 PM
I will run 13s on the mpi- this was original and I like the look. So the standard 13 x 6 s better than the 7 s?
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 13 September 2017 - 04:46 PM
I only have experience of the 7's so I don't know. The more sidewall depth you have the better the roadholding and comfort. I just like the look.
#7 Cooperman
  • 23,273 posts
Posted 13 September 2017 - 04:52 PM
The best wheel size for ride comfort and suspension is the 10". The reason for this is that the higher sidewall of the 10" wheel can take more of the suspension's work and this keeps the wheel in better contact with the road. Also, the width of a 10" wheel allows a narrower tyre than a 13" which gives better contact pressure, so the road-holding is better too. A Mini never needs more than a 165 section width on a road car and, in fact, a 145 section can be better in wet or slippery conditions.
The key to mini road-holding is the settings of the rear suspension. They are well documented elsewhere on here if you do a search.
#8 nicklouse
  • 18,556 posts
Posted 13 September 2017 - 05:02 PM
just remembered your location.
what are the rules about changing parts on your car? like Germany or like the UK?
#9 R32Egor
R32Egor
  • 299 posts
Posted 14 September 2017 - 06:07 AM
Like Germany - everything has to be passed by the TÜV and written in the paperwork which costs also - I also forgot this!!!!!!!!!!!!!!!!!!!!!
Looks like i am "stuck" with 13 x 6's.
So are there any good suspension setups for these wheels?
I am thinking -
red dot rubbers
hi-lows/adjusta ride?
Gaz short adjustables all round
Should i have some other adjustable items for camber/caster? - probably going to need to if i lower the car slightly.
#10 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 14 September 2017 - 08:45 AM
I am thinking -
red dot rubbers
Probably not what you want to hear but here goes, If you're wanting the car to handle well and you're on 13's you don't want to lower it; if anything you'll need to raise it slightly, also, you don't need as much negative camber. You certainly won't want shorter shocks.
If on the other hand you're going for a look, go with what makes you feel good. I've set the HI Lows on mine back to a fairly standard ride height after realising the lowered one was not good, I still have the1.5 neg bottom arms (but feel that's a little too much) and I've learnt to anticipate its handling foibles. Its your car just enjoy it. The biggest improvement was setting up the rear suspension on 4 wheel alignment, Spend some money on adjustable rear suspension components such as these http://minispares.co...px|Back to shop in my opinion worth every penny.
Cooperman is the man to contact for suspension set up.
#11 nicklouse
  • 18,556 posts
Posted 14 September 2017 - 08:56 AM
I am thinking -
red dot rubbers
you will not find anything adjustable with TUV also anything that look out of the normal will draw attention. EG the KAD rear arm. No TUV.
really you need to be asking on an Austrian Mini forum in regards to these type of Modifications as they will know what can be done.
things like the none adjustable bottom arms which change the camber should go through with out issues as they look standard. as would Modified rear arm brackets.
I know many Mini clubs in Germany have all the info about what can be done with no problems. and I know Companies like Limora have got papers done for some none standard parts.
look like you are going to have to go asking many many questions that we cant help with.
#12 Ethel
  • 25,909 posts
Posted 15 September 2017 - 09:31 AM
Would Rover 12" wheels cause a problem? They'd also have been standard equipment, quite possibly on the same model.
#13 AeroNotix
AeroNotix
  • 267 posts
Posted 15 September 2017 - 01:41 PM
Lordy that's a lovely mini.
#14 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 15 September 2017 - 02:27 PM
Thanks, it is until you become obsessive about keeping it clean.
