Primer Advise
Posted 09 September 2017 - 05:43 PM
Sorry about the way this is written I've read a lot on the internet and I'm super confused and don't want to wreck it at this early stage
Thanks guys
Posted 09 September 2017 - 06:02 PM
Posted 09 September 2017 - 06:06 PM
Posted 09 September 2017 - 08:36 PM
As you are doing the car panel by panel I would give your finished panel a good coat of this epoxy then just leave it and move onto the next panel until all the panels are done then sand the epoxy all over,if you break through to the metal prime again with the epoxy.This epoxy is a high build primer so you could,if you wanted to, just give it two coats of this primer, then sand the car again then apply the top coats of your choice or prime the first coat of sanded epoxy with cellulose primer, sand again and then top coat with your cellulose.
This epoxy paint can be used for your inside, outside and underside, its worth saying though that it needs to go over solid non rusty metal, if you paint it over the rust the rust is still there and will just come back, its not a rust treatment.
Hope that helps a little.
Edited by Furyan, 09 September 2017 - 08:41 PM.
Posted 10 September 2017 - 01:27 AM
if shed is damp, 2 pack epoxy it.
Epoxy primer is waterproof and tough as old nails.
I've found lechler to be the best, and can be tinted to what ever colour you want
Posted 10 September 2017 - 06:19 AM
FS
Posted 10 September 2017 - 08:15 AM
Posted 10 September 2017 - 08:47 AM
Posted 10 September 2017 - 08:51 AM
Posted 11 September 2017 - 01:33 AM
I swear by bilt hamber stuff. I'm painting a new wing on my daily just now. I'm taking it to bare metal then using a light coat etching primer, electrox, epoxy primer, then high build to get it perfectly flat and ready for base coat. All bilt hamber.
Posted 12 September 2017 - 05:52 PM
