Swap Manifold Studs To Bolts?
27 replies to this topic
#16 Cooperman
  • 23,278 posts
Posted 09 September 2017 - 07:31 PM
With either location rings or dowels (Cooper & S) it is very easy with bolts. The exhaust will not really move far out of line so long as the top engine steady is left connected and it is easy to persuade it back into place when the head is re-fitted.
I have seen an exhaust valve fitted to a Cooper 'S' in a one-hour service period on a major rally. Of course, the valve didn't get lapped in, but it lased until the end of the event.
Each to their own, but I've been using bolts since 1964.
#17 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 09 September 2017 - 08:16 PM
Not sure I follow the difficulty with alignment. The manifold are currently aligned only by the studs, I'll get the save alignment with the bikes won't I?
Educate me.
#18 Cooperman
  • 23,278 posts
Posted 09 September 2017 - 08:42 PM
I've never had a problem with re-alignment when re-fitting as the exhaust and inlet manifolds hardly move.
#19 Spider
  • 14,849 posts
Posted 10 September 2017 - 08:36 AM
I've done both ways.
Noted Cooperman and others like Bolts, but I prefer the Studs with the Long Brass Nuts. I fit it much easier to get the Manifolds lined up and a few of the middle sets, when using bolts I found a real super fiddle to get started.
Each to their own and maybe try it both ways before making up your own mind.
#20 sledgehammer
sledgehammer
  • 3,098 posts
Posted 10 September 2017 - 11:11 AM
it all depends on finger / hand size
bigger isn't always better   :shy:
also having the right spanner or socket / ratchet helps
#21 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 10 September 2017 - 12:15 PM
Yeah, that's true, I've gone through about 10 different combinations of extensions and what not to get something on some of them and be able to turn it!  The worse one falls between one size extension and another, such that it jams the ratchet against the carb before I can switch to the shorter extension, have to do that one last so the carb can move back with the nut!
Not sure if it's tighter being a Minus or not too.
#22 nicklouse
  • 18,583 posts
Posted 10 September 2017 - 12:20 PM
1/2 or 3/8s drive?
and some manifolds make it worse than other.
#23 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 10 September 2017 - 01:17 PM
I use allen headed set screws with thick machined washers on mine.
#24 Spider
  • 14,849 posts
Posted 10 September 2017 - 08:07 PM
I usually us a 1/4" drive socket set and for the middle two nuts, sometimes using a 13 mm socket instead of a 1/2" allows one to get a little extra and welcome off-set to get the job done.
Yes, I've done that too and found of the bolts choice, Cap-head bolts were considerably easier to fit up.
#25 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 11 September 2017 - 02:27 AM
I use what we call wobble sockets to get to those hard to reach inner nuts......
#26 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 11 September 2017 - 06:36 AM
I'll be taking the head off this next week to check various things and back cut the valves, I think I'll be taking out the manifold studs and finding online some hex headed unf set screws after reading this!
#27 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 11 September 2017 - 07:46 AM
I actually end up with 1/4" sockets for most of them.  I have a wobble adapter thing now that probably would help - forgot I had them - a set of proper sockets would be good to add to the kit though, not seen those before.
#28 Cooperman
  • 23,278 posts
Posted 11 September 2017 - 08:45 AM
You might note that Ford always bolted their manifolds on their cars.
