Cup Holder Hack
66 replies to this topic
#31 Marc_mcq
Marc_mcq
  • 353 posts
Posted 06 September 2017 - 07:34 PM
So today, my second tray arrived and I had a go at Mini Cupholder 2.0. I must say, much neater.
So I took the advice of a few posters and mounted the gaitor ring underneath. In order to have the tray not flex when fastened down, I made a second gaitor ring to use as a spacer using the original metal one as a template out of some 5mm thick plastic I had lying round the garage and then mounted it between the tray and the metal ring. Essentially this makes a 'tray/ spacer/ gaitor ring/ rubber gaitor/ carpet/ body shell' sandwich.
Some photos:
Painted the screw heads with some satin black for a neater finish also:
And Mini Cupholder 2.0 in all it's glory:
Cheers!
#32 greenmini1275
greenmini1275
  • 348 posts
Posted 06 September 2017 - 08:04 PM
Very nice. Looks a lot neater. I take it that it's nice and strong?
#33 panky
panky
  • 1,791 posts
Posted 06 September 2017 - 08:05 PM
Even neater :D
#34 Marc_mcq
Marc_mcq
  • 353 posts
Posted 06 September 2017 - 08:23 PM
Much neater! Yeah, with the 5mm spacer underneath, it allows you to fasten the screws nice and tight without distorting the shape. All parts of the 'sandwich' were glued together before fastening down too, so its lovely and stiff now!
#35 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 06 September 2017 - 09:19 PM
well done. can't beat a bit of r&d for the rest of us. fair play. you'll start manufacturing them next, :-)
#36 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 06 September 2017 - 09:23 PM
It looks real good, nice to see a bit of fabrication.
#37 greenmini1275
greenmini1275
  • 348 posts
Posted 06 September 2017 - 09:26 PM
I might need to have a go at this.
#38 mk1leg
mk1leg
  • 9,343 posts
Posted 06 September 2017 - 09:58 PM
there are some great cup holders from here,,,,,,,   https://www.facebook...?type=3
#39 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 06 September 2017 - 10:02 PM
Where's the fun in those, they're already made, there's no opportunity for some cursing.
#40 Marc_mcq
Marc_mcq
  • 353 posts
Posted 06 September 2017 - 10:04 PM
Make sure you post in here when you do, would be interested to see if you make any improvements on my 'design'!
#41 Marc_mcq
Marc_mcq
  • 353 posts
Posted 06 September 2017 - 10:07 PM
They look pretty good! Can't help but think that knuckles would be getting pretty close when selecting 1st and 3rd gears!
It's not fun if you don't end up with blood drawn!
#42 greenmini1275
greenmini1275
  • 348 posts
Posted 07 September 2017 - 07:44 AM
I've always wanted to see firstly, how these are fitted, secondly one actually in place and thirdly a picture of someone's hand on tne gear knob when in first or third. Also, how does it work with the heater? Does it effect airflow?
#43 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 07 September 2017 - 08:15 AM
Hopefully the heater will keep the coffee warm  :proud:
#44 lawrence
lawrence
  • 1,340 posts
Posted 07 September 2017 - 01:41 PM
So mine arrived this morning, spent not time in cutting it up :)
36269826013_b981707eab_b.jpg20170907_113407 by Lawrence Balls, on Flickr
fitted together
36941914051_b32a391d83_b.jpg20170907_115431 by Lawrence Balls, on Flickr
and in the car.
37083312875_e7f65146c9_b.jpg20170907_115556 by Lawrence Balls, on Flickr
not secured yet but ill probable fit it with some black self tapping screws or make some fancy mount the back slides into and then have one screw at the front in the cupholder part and put some foam in there to cover it up and keep things tidy!
Cheers Marc!
#45 Marc_mcq
Marc_mcq
  • 353 posts
Posted 07 September 2017 - 02:02 PM
fitted together
and in the car.
Cheers Marc!
Great effort! Looks really tidy!
It's maybe a little bit late now but could you have cut the hole a little closer to the back edge to give you an little extra storage space for bits and bobs? I wish they made one with the tray around 3 inches longer so i could utilise a bit more of the tray space for storage!
Edited by Marc_mcq, 07 September 2017 - 02:06 PM.
